junkman78 1 Posted November 27, 2018 Share Posted November 27, 2018 well with my siblings moving back home or buying houses out in the country I am the only one with a tractor. After last weekends blow I was pretty darn cold after a few hours on my 806. Seems no one makes a direct fit for a 806 any more. The one FEMCO has is for one with the clam shell fenders. I have the flat tops. Would anyone one lying around they would like to part with? Burch make a universal fit for a 806 I asked to see pictures of how it fit and they have nothing. Thank you folks. Link to post Share on other sites
IHCfarmer 7 Posted November 27, 2018 Share Posted November 27, 2018 I put the femco one on my 806! It works great I don’t know what the problem was with the clamshell fenders Link to post Share on other sites
hagan 315 Posted November 27, 2018 Share Posted November 27, 2018 3 hours ago, junkman78 said: well with my siblings moving back home or buying houses out in the country I am the only one with a tractor. After last weekends blow I was pretty darn cold after a few hours on my 806. Seems no one makes a direct fit for a 806 any more. The one FEMCO has is for one with the clam shell fenders. I have the flat tops. Would anyone one lying around they would like to part with? Burch make a universal fit for a 806 I asked to see pictures of how it fit and they have nothing. Thank you folks. If i remember the clam shell had a lower cut door. I do remember it had a stand that bolted to the platform to hold the door closed. The flat top fender ones had a latch that bolted to the top of the fender and the door was not cut nearly as low. I would love to find a windbreaker for my F 806 with clamshells also but i think they are few and far between Link to post Share on other sites
IHCfarmer 7 Posted November 27, 2018 Share Posted November 27, 2018 Look up heat houser I think they have one that will fit your 806! Link to post Share on other sites
7and8and1456 99 Posted November 27, 2018 Share Posted November 27, 2018 4 hours ago, junkman78 said: well with my siblings moving back home or buying houses out in the country I am the only one with a tractor. After last weekends blow I was pretty darn cold after a few hours on my 806. Seems no one makes a direct fit for a 806 any more. The one FEMCO has is for one with the clam shell fenders. I have the flat tops. Would anyone one lying around they would like to part with? Burch make a universal fit for a 806 I asked to see pictures of how it fit and they have nothing. Thank you folks. Get from Femco one for 756, 856, 826, etc . http://www.femcomfg.com/index.php/products/weather-protection Number 307021429 . They are for flat fenders. It will work on your 806. You may have to use a piece of flat bar stock and drill some holes in it to make an extension to bolt to the deck plate of tractor for it to fit perfectly as 06 deck is not quite as wide as 56 & 26 series. Also here https://www.tractorpartsasap.com/heater-cab-kit-red-vinyl-international-756-826-856-1026-1256-1456-123046.html Link to post Share on other sites
7and8and1456 99 Posted November 27, 2018 Share Posted November 27, 2018 1 hour ago, hagan said: If i remember the clam shell had a lower cut door. I do remember it had a stand that bolted to the platform to hold the door closed. The flat top fender ones had a latch that bolted to the top of the fender and the door was not cut nearly as low. I would love to find a windbreaker for my F 806 with clamshells also but i think they are few and far between Femco shows them for 06 tractors with clamshell fenders. number 307021331 http://www.femcomfg.com/index.php/products/weather-protection Also get then from here .... https://www.tractorpartsasap.com/heater-cab-kit-red-vinyl-international-706-806-1206-123044.html Link to post Share on other sites
junkman78 1 Posted November 28, 2018 Author Share Posted November 28, 2018 Thank you again. i will look into both. 7and8and1456 have any pictures with the 756 model mounted to a 806? IHCfarmer do you happen to have a part number of what you used? Link to post Share on other sites
John cub owner 132 Posted November 28, 2018 Share Posted November 28, 2018 This is a little bit off the planned topic, but I remember when I was in my early to middle teens (very long ago), and we had an H. Our farm was at the end of a valley where it began to narrow, but the valley ran about 7 or 8 miles to the NW. The wind would come through that valley and when t reached our farm where it narrowed, it would pick up speed.. On a bitter cold windy day that was the coldest spot for many miles. One day Dad came in with a windbreaker for the H. I don't know where he got it, it was not new, but in like new condition. It included the flaps that went beside the engine to the radiator housing. Dad had an old heavy duty umbrella of some kind that had a double arm on it, and when we put it on it would set down right on top of the windows for the windbreak, so the only opening was the rear. I thought I was in hog heaven. The man that bought the 2 of them at our farm sale 25 years ago gave them back to me last year, but they were too badly deteriorated and too many parts missing to refurbish. Link to post Share on other sites
junkman78 1 Posted November 30, 2018 Author Share Posted November 30, 2018 On 11/27/2018 at 9:21 AM, IHCfarmer said: I put the femco one on my 806! It works great I don’t know what the problem was with the clamshell fenders do you happen to have the part number of what you used? On 11/27/2018 at 11:34 AM, 7and8and1456 said: Get from Femco one for 756, 856, 826, etc . http://www.femcomfg.com/index.php/products/weather-protection Number 307021429 . They are for flat fenders. It will work on your 806. You may have to use a piece of flat bar stock and drill some holes in it to make an extension to bolt to the deck plate of tractor for it to fit perfectly as 06 deck is not quite as wide as 56 & 26 series. Also here https://www.tractorpartsasap.com/heater-cab-kit-red-vinyl-international-756-826-856-1026-1256-1456-123046.html Do you happen to have any pictures to confirm this? Link to post Share on other sites
7and8and1456 99 Posted November 30, 2018 Share Posted November 30, 2018 9 hours ago, junkman78 said: do you happen to have the part number of what you used? Do you happen to have any pictures to confirm this? Sorry , I do not have picture . Link to post Share on other sites
IHCfarmer 7 Posted December 1, 2018 Share Posted December 1, 2018 That’s it I used the one for an 856 works great will try to get you a couple pics tomorrow Link to post Share on other sites
Cool1566 561 Posted December 1, 2018 Share Posted December 1, 2018 It would be nice if someone would offer reproductions of the originals. Link to post Share on other sites
Wes806 1,489 Posted December 1, 2018 Share Posted December 1, 2018 8 minutes ago, Cool1566 said: It would be nice if someone would offer reproductions of the originals. Nice I like the looks of it. Good looking tractor there Link to post Share on other sites
nomorejohndeere 419 Posted December 1, 2018 Share Posted December 1, 2018 doesn't look to hard to make one Link to post Share on other sites
7and8and1456 99 Posted December 2, 2018 Share Posted December 2, 2018 6 hours ago, Cool1566 said: It would be nice if someone would offer reproductions of the originals. I have an original IH Windbreaker that is used on 756, bought it many years ago. Later, I wanted one for 856, but no longer available from Case IH. I bought a Femco. It is identical to the IH original except for the name painted on the fabric. The instruction sheet that came with the Femco was a direct copy of the sheet with the IH. No doubt in my mind that Femco ( or same company with another name at the time) made them for IH. Just like IH had some companies to build cabs for the tractors when cabs started being available. Link to post Share on other sites
billonthefarm 904 Posted December 2, 2018 Share Posted December 2, 2018 I agree that the femco made ones are dead ringers for the IH ones. Link to post Share on other sites
sandhiller 14,780 Posted December 2, 2018 Share Posted December 2, 2018 Well, here we go, since this topic came up I just as well admit I piddlefarted around and couldn't decide which comfort cover to get so never got one. It would have been really nice to have today and since I do this on my 966 with cab just to keep heat in the motor and fuel filters when it gets below 0. Nobody local will see me and I know you guys won't tell?!? It really worked pretty good at directing engine heat back to me, a lot better than nothin' at all. I may not have all the bulbs lit on my Christmas tree but I hope you will get a kick out of this and laugh with me and not at me. Cows are fed, I'm back in the house, time for a hot toddy! Link to post Share on other sites
Matt Kirsch 889 Posted December 3, 2018 Share Posted December 3, 2018 This is a 706 that Tractor Supply had as their IH toy for Christmas a few years back. Just remembered that I had it. Link to post Share on other sites
junkman78 1 Posted December 3, 2018 Author Share Posted December 3, 2018 well if i can round up the cash looks like im gonna try one for the other series of tractors. I will document how installation and modification goes. Thanks everyone. Link to post Share on other sites
