Hootmon 0 Posted November 11, 2018 Why would oiler gear suddenly break around countershaft? Had proper amount of gear oil in transmission. Quote Share this post Link to post Share on other sites
mmi 153 Posted November 12, 2018 Just now, Hootmon said: Why would oiler gear suddenly break around countershaft? Had proper amount of gear oil in transmission. Welcome OOOmmy BTDT bad bearing ........frozen x.....was it that cold yet? just their time cheap aluminium way past engineered life unfortunately likely only getting a used one $75 + S if it is that much have them magnaflux guarantee like new..for a good run in.....week..sure they cant know 2 weeks or 30 hours later hopefully you did not loose $$$$$other parts since you will be doing a complete rebuild check every part in there and let it take several months/evenings Quote Share this post Link to post Share on other sites
GT&T 9 Posted November 12, 2018 Hootmon These oiler gears are made of a poor grade of "pot metal" and are very prone to breakage. If yours is still around the shaft you can break the remains and remove the pieces after removing the shift cover. This gear was installed to ensure oil to the gears when the tractor is used for stationary PTO or belt work. If you don't do any stationary work or let the engine run for long periods of time, when the tractor is not moving, I have run them for years without the oiler gear. GT&T Quote Share this post Link to post Share on other sites
560Dennis 634 Posted November 12, 2018 Good post , I never noticed that on the c or sc . I found a some strange stuff stuck in differential sludge , changing the oil. Quote Share this post Link to post Share on other sites
Hootmon 0 Posted November 12, 2018 Thanks for response, picked oiler up on eBay. Never thought i would be this far into a tractor tranny before. Quote Share this post Link to post Share on other sites
560Dennis 634 Posted November 12, 2018 1 hour ago, Hootmon said: Thanks for response, picked oiler up on eBay. Never thought i would be this far into a tractor tranny before. Take lots of pictures , never know when I might need them 👍🏿🚜 Quote Share this post Link to post Share on other sites
