TDC5 international steering clutch
Hi I recently brought a much used drott the steering clutch on one side is the fibre disc metal disc combination the other which has striped the centre hub has bonded fibre plates with steel teeth in the centre,
which option would be the better or easier,do I change over to all fibre discs or find a new hub to suit the bonded plates.
Sand blast the fiber plates and if some of the linings have come loose you can epoxy them back on after sandblasted . Surface the floater plates and it will work great !!
Danny
Danny
Danny
Will do ,I found a website steering clutch.com they have the hub listed so if they have it in stock i will be away.
