Farmall8061964
Distributor
Might be a bit different but it will work, same engine.
Only real difference would be the mechanical advance. 706 might advance a few degrees more because the engine runs several hundred RPMs faster.
Most likely the ignition points will be different. 560 used the early style, 706 started using the later style.
