Cooter 14 Posted September 30, 2018 Share Posted September 30, 2018 Cool project tractor. Did you put rear tires on it to get it loaded? Are those factory loader lines that come out from under each side of the platform? Link to post Share on other sites
VacDaddyt 176 Posted October 2, 2018 Share Posted October 2, 2018 I often wondered what a tractor would look like all taken apart and laid out in rows.. Now I know. Good luck on it. I have seen your work as it will be nice when you are done. Link to post Share on other sites
Long Farms 1,764 Posted October 3, 2018 Author Share Posted October 3, 2018 Cooter, tractor still sits on stands where i last saw it. Guy is busy defoliating cotton and its still hot enough not to mess with it. Nice 70 deg day sounds like a the day to mess with it. Alot of crap to move out of the after i get it ready to roll. Link to post Share on other sites
B.B. 669 Posted October 4, 2018 Share Posted October 4, 2018 Can that be safely moved with the frame rail off the one side? I'd offer to come help you move it, but it's a heck of a drive! Link to post Share on other sites
Diesel Doctor 2,091 Posted October 7, 2018 Share Posted October 7, 2018 Can you get it home before the wife winds out under the 48 Hour Rule? Wish it was mine. Some assembly required and one bolt at a time. Link to post Share on other sites
Long Farms 1,764 Posted October 7, 2018 Author Share Posted October 7, 2018 8 minutes ago, Diesel Doctor said: Can you get it home before the wife winds out under the 48 Hour Rule? Wish it was mine. Some assembly required and one bolt at a time. She was asking last night when were gonna go get it. As of yesterday it was still getting in the 90s and im not messing with it untill it cools off more. Link to post Share on other sites
Long Farms 1,764 Posted October 29, 2018 Author Share Posted October 29, 2018 Link to post Share on other sites
TP from Central PA 3,166 Posted October 29, 2018 Share Posted October 29, 2018 Hey! Why can't I ever come across one of those Red Boxes!!!!!!!!!!!!!!!!! Link to post Share on other sites
Wes806 1,489 Posted October 29, 2018 Share Posted October 29, 2018 Looks to be a good project. congrats on finding it. Will be watching progress. Know it will turn out good as all your project's does. Link to post Share on other sites
Nebraska1206 153 Posted October 29, 2018 Share Posted October 29, 2018 Cool, glad you got it home, Brian! Link to post Share on other sites
B.B. 669 Posted October 29, 2018 Share Posted October 29, 2018 10 hours ago, TP from Central PA said: Hey! Why can't I ever come across one of those Red Boxes!!!!!!!!!!!!!!!!! What's that for? Link to post Share on other sites
TP from Central PA 3,166 Posted October 29, 2018 Share Posted October 29, 2018 Flow rater from IH. Reads flow and pressures. Link to post Share on other sites
B.B. 669 Posted October 29, 2018 Share Posted October 29, 2018 21 minutes ago, TP from Central PA said: Flow rater from IH. Reads flow and pressures. Ahh ok. Thanks for answering! Link to post Share on other sites
Long Farms 1,764 Posted October 29, 2018 Author Share Posted October 29, 2018 Replaced a rubber power steering hose with correct steel line, wired dash panels, ran front main and rear main wire harnesses, installed starter, mounted fuel tank. Calling it a day. Glad to see it still has factory 3LD-279 turbo. It was super easy to install stater and run wires with fuel tank off. Link to post Share on other sites
Nebraska1206 153 Posted October 29, 2018 Share Posted October 29, 2018 Man, you put in a lot of work in a short amount of time! Dang! Very nice! Link to post Share on other sites
lorenzo 13,966 Posted October 30, 2018 Share Posted October 30, 2018 I checked the pictures over very closely, it’s missing three bolts and a lock washer. But seriously , a 1026 hydro would be a nice addition to any collection that’s for sure . Link to post Share on other sites
Wes806 1,489 Posted October 30, 2018 Share Posted October 30, 2018 1 hour ago, Nebraska1206 said: Man, you put in a lot of work in a short amount of time! Dang! Very nice! X2 Link to post Share on other sites
nepoweshiekfarmalls 2,069 Posted October 30, 2018 Share Posted October 30, 2018 In my experience, assembly from the point you started from is about 3 days. Be driving it around next weekend!😁 Link to post Share on other sites
B.B. 669 Posted October 30, 2018 Share Posted October 30, 2018 2 hours ago, nepoweshiekfarmalls said: In my experience, assembly from the point you started from is about 3 days. Be driving it around next weekend!😁 Yeah maybe when you're the guy that took all the bolts out to begin with. Probably not so when you have to go looking for them! Link to post Share on other sites
Long Farms 1,764 Posted October 31, 2018 Author Share Posted October 31, 2018 I hate dirt dobbers but they do take out alot of spiders. Turbo sleeve and bottom of exhaust elbow was solid dirt dobber nest. Had the grease my hand to be able to get it in the elbow to grab and pull out the nest. Changed the engine oil and filters and fuel filters. 10 gal of fresh diesel, hot 12v battery and it fired in less than 10 sec. Gotta love 407s. Drives forward and reverse. Taking it easy since it hasnt ran in 2yrs+. Major hyd leak on steel line under starter. Looks like its pitted and rusted through. Drove it into work shop where i can work on it more comfortably. Link to post Share on other sites
Gleaner k2 34 Posted November 1, 2018 Share Posted November 1, 2018 Looking good! Its always nice to hear something fire back up for the first time! Especially when everyone else says it will never run again! Link to post Share on other sites
Long Farms 1,764 Posted November 6, 2018 Author Share Posted November 6, 2018 Link to post Share on other sites
MarkG 870 Posted November 6, 2018 Share Posted November 6, 2018 Looking good! Will running it without coolant hurt the seals in the water pump? Link to post Share on other sites
Wes806 1,489 Posted November 6, 2018 Share Posted November 6, 2018 Looking good. You sure have come along way on it. Link to post Share on other sites
FarmallMMark 47 Posted November 6, 2018 Share Posted November 6, 2018 I really like that hydraulic test unit! Very neat find! Link to post Share on other sites
