1958560
Mx110 powershift
Buddy has a mx110 that the 1st powershift slips when engaging clutch at a high rpm. It will catch and pull so far but seems slow to engage. If the clutch is engaged at a low idle it will engage and pull good when you accelerate. It sounds to me like the clutch pack for 1 powershift is starting to let go, but I'd like to check pressure to be sure. Anyone know where to check and what pressure to look for? Tractor has been under a loader its whole life and has over 12k hours on it, but he takes good care of it. Thanks, Robert
Right in behind battery box on right side of transmission housing is the power shift manifold. It will have 2 shift solenoids on it and 4 test ports. Test ports #s should be embossed in the casting. 280-310 psi
Thanks! Do you have any idea what size fitting is required?
M14 x 1.5
Thanks again! Should have time to check it out in the next few days. Should be able to just shift thru powershift ranges with trans in neutral to check pressure right?
