49' McCormick ODS6
On 9/8/2018 at 8:05 AM, SAM86 said:
August this year we got word of a local farm auction with equipment we knew the history of sold previously from a firends farm auction. One piece was a WD6 that had been overhauled with a complete new top end and all headwork.
We were able to buy it and it came with a new radiator to boot. I needed another radiator as I stole the one off the ODS6 for the OS6.
Been doing the engine swap over the last month with help fom my brother. Had to replace the rear main seal due to badly warped retainers. Changed all fluids and filters.
Started it for the first time yesterday, rack was stuck closed in the pump and had a bad miss in one cylinder. with a little patients we freed up the rack and a balve adjustment cured the miss. To surprise this is probably the smoothest of the gas start diesels we have.
Took it out for my maiden ride yesterday. Still lots of tinkering to do. Have to make the exhaust so I can put the hood on.
I like the wall color paint ,the spray gun patterns
3 hours ago, redturbo said:
I was told OS4 & 6’s are wider than the O4/6.  Is that true?  Brought this brochure online last month.
Both O and OS models can be configured the same. No difference up front, on the O's, the rear hubs are inset for a narrower track and have to be this way for the rear enclosed fenders. OS models can run the hubs inset or outset, typically you see the latter for some additional stability.
10 hours ago, SAM86 said:
We are right in the heart of apple country in Sodus, NY. There were alot of the orchard series tractors used in the area. Big farm across from my grandparents old farm had five ODS6 tractors opperating at the same time many years ago. This is one of them. I recall seeing quite a few listed in Michigan for sale and know of some people making multiple trips to MI picking them up. You should be able to find one close. The rest of it is all timing. To be honest the IH and Farmall group pages and Marketplace on Facebook have been one of the best resources lately.
Ahh i see. Majority of them around here are either getting picked up for scrap, or being parted whole :(
What are some good FB groups to find these? Would love one.
Yeah I didn't care about the drywall when I was painting, it has several damaged spots and has to come down anyway so I can insulate the walls. I just got the ceiling up, insulated and looking propper so now the "test spots" are starting to annoy me. Plus one of the overhead doors decided to commit suicide a week ir so ago so those are on the to-do list as well.
Some are area dependent but to name a few....If you join one or two some recommendations start to show up for others.
Ods6 Nice projects ,glad you taken the time to save the os , do you have the fenders for the bigger tractor ods6?
any way good  for you ??
Was that the Only IH Orchard brochure on eBay I'd love to have that!
I'm in the IH group, Just joined the IH-Wheatland and Standards as well as this one https://www.facebook.com/groups/1744741302453245/?hc_location=group
Sam explained it well, I prefer the wheels set in on an OS the same as a O because the fenders /operators platform are narrower than a W so it looks odd with the extra space between the fenders and wheels
Just my preference
17 minutes ago, redturbo said:
Is there any rhyme or reason to the solid front wheels to open spoked?
Solid wheels came with the creeper low 1st gear.
Hello, I see you got the injectors out of the head.  I am working on a WD6 and one cylinder is in pretty rough shape.  I need a new liner for it because of rust so bad I cannot hone it out.  I also want to pull the injector to see if it is rusted, but it is in there pretty solid.  Can you share your technique?
I also see that you have new spark plug chamber valves, where did you get those, I as well would need to replace the one and the exhaust valve on the rusted cylinder,  Surprisingly the intake valve was pristine.
I made a puller for the injectors out of some c-channel. Bolted the channel to the injector and had two jacking bolts that pushed on the head to pull the injector out.
All of the valves are available through various companies, the first on that comes to mind is Bates corp. Hold your breath and be ready for sticker shock. The shop that did all of my head work actually made me new staring valves cheaper than they could be bought.
  • 3 weeks later...
I tried to buy that brochure at an auction in January. Maybe I was running you up. If so, sorry!
Anyway, to make up for it, here's a scan from the 1949 master sales catalog with dimensions. They do show overall widths being wider on the O's but that makes since, on account of the fenders. Notice that the front and rear wheel center-to-center dimensions are the same between O's and OS's. For fun, I included the page with W's' dimensions. You can see they're wider than the orchards.
image.thumb.png.0dd303e36a12707908675fa0576b111d.pngimage.thumb.png.b671b9053367117325e14875e47a20c2.png
I've asked this same question before and I've never been convinced of any real reason. I have yet to find evidence that it wasn't war rationing. Now, so as not to confuse people, this is purely my own theory, but we know IH (and all the others) were limited in what they could produce during the war, and those solid wheels are a LOT of cast iron. I've never seen solid wheel on a war year orchard. I've seen spoked wheels on a post war machine, but that could have been old stock too. I frankly do not know.
I'd love to know for sure, and maybe you could set me straight. I'd appreciate that. Where did you hear about the low 1st-solid wheel relationship from?
Mine is a ‘49 that originally came with solid cast fronts. Grandad and most guys in the area put standard spoked wheels on as to make steering easier. I’d have to really do some more research but I’ve heard it a few times over the years that the cast wheels indicated a low, low first gear.
  • 4 months later...
2 hours ago, CubNamedOscar said:
For Research purposes, what was Different from the Gas Orchards to the ODS (s)? I am considering on making a 3D model for a Game I play (Farming Simulator)
Diesel engine, fuel cap is taller, and an extra lever for the gas to diesel change over mechanism on the steering support. Other than weight, dimensionally the are the same.
Thanks.
  • 3 weeks later...
The earliest O-4 came out with the 3 spoke front wheels. Once these tractors got into the orchards it was noted that tree branchs were penetrating the wheel openings and twisting the branchs off. This necessitated a change to the solid front wheels to protect the trees. I'm not sure if the were then standard equipment or as an option but a benefit arose when they noticed the front ends of the tractors wouldn't lift as easily in a heavy pull. The earliest O-4's had a tendency to snap the axle ends when the fronts lifted and the weight came down on the outside edges of the front wheels. The changes of a heavier web thickness of the axle, heavier wishbone and a spring pack above the axle to prevent drooping of the front axle came into effect. Note: when an H or M was ordered with the low low gear the heavy/solid front wheels are typically on them as well. War years may have been an influence on the option of the solid wheels, I don't know.  Hope this helps muddy the waters.
