Life of a Feed Delivery Guy
redneckchevy9
I wasnt driving up here when all the others turbines were built, but this last one was being put up last Thursday just outside of Cobb, WI.  I have a feeling that the construction of these was probably opposed by area people.
  • Replies 159
  • Created
  • Last Reply
Bet they did. I know alot of people don'nt want them put up down where I'm at but a few has went up. Nice pics thanks for sharing
I was getting fuel across the road from the Kinzie plant just off I80.  This cool site came rolling in as I was leaving the fuel island....so I had to stop and get a closer look.
The nice older gentleman was from down by Hannibal, MO and just picked up this freshly restored MTA from a gentleman in Montecello, IA.  If I remember, I think the guy he bought it from worked out of the old IH dealership in Montecello.  It was sure a nice tractor...and so was the 20 minute conversation I had with the old farmer.  Found out he likes to make Ms into 100hp pullers back home.20181029_111529.thumb.jpg.87989cc0df7c0d6554d67089a867669c.jpg
3 hours ago, sandhiller said:
I've owned a lot of M's, never one that nice. I believe I would chain it down differently though.
I noticed the lack of protection of paint, but it is not mine and it was secure.  In talking to him and while I was taking these pictures, he was running a 3rd chain....due to Iowas 3 chain law.  I offered him a few rags to help keep chains off the paint.
So I made a trip up to Glen Haven, WI for the first time and then went cross country to a normal stop in Albany, WI.  Some of the trip was under darkness, but I did get to snap a few interesting things...at least to me.
1. Cool copper dome of the county courthouse in Lancaster, WI.
2. Never seen a Hamms Beer sign outside a bar...this is is Beetown.
3. I find old barns painted up with sayings or old advertisements so cool.
4. I am not used to see these signs...I did 2 of them....with flashers....how does that work?!
5.  Very cool retro gas station complete with a covered drive thru in Montecello, WI.
I've been by Monticello a few times,  next time I better take a few minutes and drive around town.  That gas station is Very old!  Hamm's beer sign too.
Nice looking SM-TA too!  Reminds me of driving Dad's SM-TA home from repaint in Osco when I was about 8-9 yrs old.  Dad paid an extra $5 and got the grill below the seam painted white.  Did the same thing on the '39 H a few months later, did the '51 M that way few years later,  I did the SH that way summer of '69. when I repainted all the sheetmetal,  actually, I did all the wet sanding, bought all the paint, Dad sprayed everything.
They put up a couple on coastal islands in Maine that are mostly inhabited in summer by out-of towners from Massachusetts, CT, NY, and NJ. They all thought it was wonderful until they discovered how much noise they make. Now they just run during the day...
1 hour ago, jass1660 said:
Thank you farmers is from Culver’s restaurants
I guess the color of barn makes sense then.
How would you have chained it?
I used to go behind the steering pedestal over top of front tires. In back, I would go through the rear wheels near the bottom. If I was worried about paint, I had old mudflap to use.
Makes sense to me
Why is that better
1 minute ago, IH Forever said:
Why is that better
 I don't like hanging that back chain off the back of the drawbar on the end of a clevis (one point in the center), by going through the wheels, it is effectively tying to two points and more solid.  and I don't like chaining to that front casting run through a clevis(IMHO that front casting is more for a straight pull, not an up or down load). Will chaining down this way break that casting, probably not but I don't want to find out. I feel the way I do it now anchors the tractor to the deck of the trailer solidly. Personal preference, that is all.  Have I chained it his way, yes, did I have a bad experience, no. There are many acceptable ways to secure a load and in the end it is up to the driver to be confident in the way he does it.
thanks for the explanation...that makes sense also since you are going for downforce onto the deck and not only binding down for lateral movement.
  • 3 weeks later...
Some randoms from the past couple trips
Amish convoy near Cobb, WI...it was a cold morning
New Savanna/Sabula Bridge...big improvement from old narrow steel grate bridge
2 hours ago, mader656 said:
That seems like a really good way to test a loader with the 4 tracks...
Never seen a setup like it
I would not use a single chain on a clevis, if machine moves chain will just slide through clevis.   I would use four chains with four binders on four corners, but that's just Me not wanting a ticket from DOT or loosing a load.   It is not the normal haul that gets Ya, it's the time You have to avoid the four wheelers that cause load to shift.
X2
The consensus on FB is they are set up to be snow groomers...some have seen them in use on snowmobile trails up north.
Till a stellar employee takes the loader to dig and ram bam broken something
I like a four point tie  .
    On most of mine I have chain loops attached to each side of front bolster /rail on rear I tie on each side of drawbar or hitch.
    Four chains four binders.
         Bears are hungry out here .
      Tony
