IH Skid steer made by Hydra mac?
CubNamedOscar
On 2/5/2021 at 11:06 AM, CubNamedOscar said:
IF anyone is interested / Has Facebook here is my group. https://www.facebook.com/groups/HydraMac/
Yep I am a member
I currently have a IH 4140 and it has the chrysler 4 cylinder gas. Parts are still around just takes some searching. I just got done rebuilding mine. New driver gears,hoses, water pump ,govenor, starter ECT. As far as I know a 12c is the same size just different motors.
ihmadness, I have a question for you. I recently picked up a 4140 with the Chrysler engine, but it is running a bit rough. I planned to start with new points, cap, plugs and plug wires. Also check the timing. Is there a way to get to the front of the engine (at the back of the machine) without draining and removing the entire radiator assembly, i.e. radiator swings to one side or the other?  Thanks for any advice you or anyone else can provide!  DonO-MN
No, I am afraid not. I have at times though just taken the top radiator hose off and the nuts and tilted the radiator back enough to get to the belts and fan. You lose a little fliud but not a bunch. Also I ran into a problem a couple years ago of the same thing of it running rough. I changed every thing you are going to but it ended up being a bad carburetor.
I almost got the chance to buy one... but the guy never got back to me! grrr!!! So yes the only Chrysler 4cyl i know of is that God awful H105.
American Eng, Licensed for England's Small cars during the 70s & Early 80s. The one i looked at the eng needed a Rebuild... Whilst searching on Craigslist i come across another guy in WIS who had a 4140 & could only find 1 Engine shop here in the U.S who could get Rebuild kits ($2800) Otherwise you have to find a Kit in England. Which was over $3000.
On 2/5/2021 at 4:09 PM, nepoweshiekfarmalls said:
Hackert sales is long gone now.  Just for reference.
Noted. There is still John @ GeardriveParts.com & Doug @ Pocahontas Equipment. Both still have parts, manuals, Diagrams etc.
  • 3 weeks later...
ihmadness or anyone else out there know where and how to drain the engine oil on that 4140 skid steer with the Chrysler 4 cylinder gas engine? I did buy a manual for servicing the skid steer, but we are in the middle of moving and all my books are packed away so far, it might be months before I can lay my hands on them. Thanks, DonO
The oil drain plug is on the left side down by the wheel if you are standing behind the machine. The first one is the oil and the other one closest to wheel is for gear case under the seat. Unless some one changed them. Just follow the hoses.
