EDWARD886 Posted August 7, 2018 Share Posted August 7, 2018 Gentlemen, I need someone smarter than me to tell me if I can put a dt466 in a 886 tractor. will it match up??? I currently have a 358 aaaannnnd A-shes not big enough and B-it will be cheaper I think to get more power Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 8, 2018 Share Posted August 8, 2018 Tractor frame's essentially the same from the bell housing forward for the first 766 through the last 1586, so yeah, a Dt466 will fit with the right parts. Any tractor with a 414 or 436 in it already will have those parts, so anything with a 9, 10, 14, or 15 in front of the 66 or 86 will have the parts you need, and are very common. If you were using it to farm, you'd tear up the 886 rear end pretty quick with a 466. Quote Link to comment Share on other sites More sharing options...
R190 Posted August 8, 2018 Share Posted August 8, 2018 Frame channels , radiator ,and steering lines are unique to the nuess powered tractors otherwise the the engines out of a bigger 66- 86 tractor will fit with out many extras the 436 may be a much better choice as the 466 was not used in any ag applications where you would not have to buy either a front cover or rear cover ,oil pan ,and sump except an engine out of a 3488 and there the flywheel is not normally machined for a pilot bearing. Quote Link to comment Share on other sites More sharing options...
rsscott Posted August 9, 2018 Share Posted August 9, 2018 Is the 358 broken? If not, why don't you just buy you a bigger tractor? Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted August 10, 2018 Author Share Posted August 10, 2018 On 8/9/2018 at 12:03 AM, rsscott said: Is the 358 broken? If not, why don't you just buy you a bigger tractor? no its not broken, works extremely well. it is just not turboed and I want to make more power for pulling Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted August 10, 2018 Author Share Posted August 10, 2018 On 8/8/2018 at 12:05 PM, Matt Kirsch said: Tractor frame's essentially the same from the bell housing forward for the first 766 through the last 1586, so yeah, a Dt466 will fit with the right parts. Any tractor with a 414 or 436 in it already will have those parts, so anything with a 9, 10, 14, or 15 in front of the 66 or 86 will have the parts you need, and are very common. If you were using it to farm, you'd tear up the 886 rear end pretty quick with a 466. no its not for farming, although I have kept all the parts to turn it back into a farm tractor. I want a hot stock pulling tractor Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted August 10, 2018 Author Share Posted August 10, 2018 1 minute ago, EDWARD886 said: no its not for farming, although I have kept all the parts to turn it back into a farm tractor. I want a hot stock pulling tractor really appreciate all the info Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 10, 2018 Share Posted August 10, 2018 6 hours ago, EDWARD886 said: no its not for farming, although I have kept all the parts to turn it back into a farm tractor. I want a hot stock pulling tractor That's what I figured from the picture. Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted November 20, 2018 Author Share Posted November 20, 2018 On 8/10/2018 at 2:41 PM, Matt Kirsch said: That's what I figured from the picture. thanks pal Quote Link to comment Share on other sites More sharing options...
88power Posted November 21, 2018 Share Posted November 21, 2018 On 8/8/2018 at 1:24 PM, R190 said: Frame channels , radiator ,and steering lines are unique to the nuess powered tractors otherwise the the engines out of a bigger 66- 86 tractor will fit with out many extras the 436 may be a much better choice as the 466 was not used in any ag applications where you would not have to buy either a front cover or rear cover ,oil pan ,and sump except an engine out of a 3488 and there the flywheel is not normally machined for a pilot bearing. The front and rear covers flywheels and tractor oil pans on 414 436 and 466 all interchange the 52 and 5488 uses 466 also Quote Link to comment Share on other sites More sharing options...
88power Posted November 21, 2018 Share Posted November 21, 2018 Got a cih reman 466 in a 5088 with a muffler delete a stock 5288 cih reman pump set at 17 degrees and the stock 5088 turbo on the Dyno turns 200 and that's not trying Quote Link to comment Share on other sites More sharing options...
MarkG Posted November 21, 2018 Share Posted November 21, 2018 4 hours ago, 88power said: Got a cih reman 466 in a 5088 with a muffler delete a stock 5288 cih reman pump set at 17 degrees and the stock 5088 turbo on the Dyno turns 200 and that's not trying What was the price for a reman 466 from cih if you don't mind me asking? Quote Link to comment Share on other sites More sharing options...
88power Posted November 22, 2018 Share Posted November 22, 2018 3 hours ago, MarkG said: What was the price for a reman 466 from cih if you don't mind me asking? I'm wanting to say it was around 6000 it's been a few months ago they have gone up since the last time we bought one but that's been a few years ago. Are dealer said it was getting harder to find them but we got ares pretty quick Quote Link to comment Share on other sites More sharing options...
Drewu223 Posted November 30, 2018 Share Posted November 30, 2018 If you get a DT466 you better be careful, it's dangerously easy to get 550-600hp if built correctly? 1 Quote Link to comment Share on other sites More sharing options...
Thesd5488 Posted December 15, 2018 Share Posted December 15, 2018 On 11/30/2018 at 10:41 AM, Drewu223 said: If you get a DT466 you better be careful, it's dangerously easy to get 550-600hp if built correctly? Ya but they start to run real nice there 1 Quote Link to comment Share on other sites More sharing options...
iA Sage Posted December 30, 2018 Share Posted December 30, 2018 What is required to get a DT 467 in the 550-600 HP range? Just bought one and that's the range I'm looking for. Quote Link to comment Share on other sites More sharing options...
88power Posted January 1, 2019 Share Posted January 1, 2019 On 12/30/2018 at 5:15 PM, iA Sage said: What is required to get a DT 467 in the 550-600 HP range? Just bought one and that's the range I'm looking for. Are you pulling it? If so it would depend on the rules Quote Link to comment Share on other sites More sharing options...
iA Sage Posted January 1, 2019 Share Posted January 1, 2019 Not sanctioned pulling, just a few County Fair pulls and tractor rides. DT 467 is going in IH 666. Will have 11" triple clutch, TA delete, a gear slower than fourth, a gear faster than fourth and needle bearing in diff. Initially would like to utilize the original turbo with either a 11 mm or 13 mm head in pump. What can I expect from this configuration? What will break? Quote Link to comment Share on other sites More sharing options...
88power Posted January 2, 2019 Share Posted January 2, 2019 Sounds like you're heading in the right direction what did the engine come out of? what rpms you plan on running? Quote Link to comment Share on other sites More sharing options...
iA Sage Posted January 3, 2019 Share Posted January 3, 2019 Engine came out of a 5288. Planning on a 4,000 RPM governor spring. Quote Link to comment Share on other sites More sharing options...
88power Posted January 3, 2019 Share Posted January 3, 2019 I'd be looking at a steel flywheel if you don't already have one I can't remember right off the top of my head if a stock fly wheel will work in that set up and I would tighen up my steering and front end for driving down the road Quote Link to comment Share on other sites More sharing options...
iA Sage Posted January 3, 2019 Share Posted January 3, 2019 Stock flywheel will not work. It's 14" and there is only room for an 11" clutch, hence the triple disk 11". The flywheel and pressure plate are steel to withstand the HP and RPM. Front end has been tightened with new components and the toe-in has been set. The 5288 engine will require considerable modification, i.e. the turbo will need to be in a position similar to the 66 and 86 turbo engines. The fuel filter assembly will need to be lowered similar to 66 and 86 engines. This is not just a simple bolt in project!! Quote Link to comment Share on other sites More sharing options...
88power Posted January 3, 2019 Share Posted January 3, 2019 Get a 66 manifold and fuel filter assmbly they all 400 series dt's work the same Quote Link to comment Share on other sites More sharing options...
iA Sage Posted January 3, 2019 Share Posted January 3, 2019 That's the plan. Should I keep the turbo off the 5288? Quote Link to comment Share on other sites More sharing options...
88power Posted January 4, 2019 Share Posted January 4, 2019 Since you got to change manifold I'd go ahead and change we have always used 3lm but if you look up the post about 5488 turbos everyone over there says s2e is the way to go I gotta get one for the 52 I think I may try one never have before Quote Link to comment Share on other sites More sharing options...
