IH504 Posted August 3, 2018 Share Posted August 3, 2018 I have nearly got my loader on my IH 504 but am lacking just the fitting to hook my supply line to the control valve stand. These pictures show the valve mounted on my IH 2001 loader and the second shows the hole in which I need to connect. Next to it is a 1 inch nipple and reducer to a 1/2 inch hose, but the open port is smaller than 1 inch but bigger than 3/4. What am I looking for? These holes are NPS thread. Quote Link to comment Share on other sites More sharing options...
mmi Posted August 3, 2018 Share Posted August 3, 2018 pull up one of the conversion charts and cross match what is between some measure od some id may need sae and or oring are the 2 holes the same...? take the reducer to you local supplier..... that looks like common place for sae oring to jic Quote Link to comment Share on other sites More sharing options...
R190 Posted August 9, 2018 Share Posted August 9, 2018 I have never seen that block with anything but orb the hole you are showing looks to take an orb fitting Quote Link to comment Share on other sites More sharing options...
BOBSIH856 Posted August 10, 2018 Share Posted August 10, 2018 Here are the specs for o ring ports from the Parker bible. Quote Link to comment Share on other sites More sharing options...
IH504 Posted August 15, 2018 Author Share Posted August 15, 2018 After many tries, I finally found a match, it is a 14 with o ring, that usually is used on Fords. Now I just have to get all the leaks tightened up. Quote Link to comment Share on other sites More sharing options...
