mader656
Sometimes you need. A bigger hammer
Yup it moved
I did a similar job to knock wheel wedges out of a 4020 that the jack bolts were stripped out.  Hung a 90 lbs. jackhammer from the forks on the loader tractor and gave it the business.  They came out.
Yup, that there is a BFH if I ever seen one.
That's better than trying to find someone to hold the punch, while you swing the sledgehammer!!!
  • Confused 1
Work smarter not harder
About a week later we had to do the same thing to a pin on a 135 foot. Took a torch too...that pin got replaced....
I've used the idea other places such as drive shaft yokes and such.
Recently I drove in an 8' 5/8" ground rod, I could have used something other than the the 10# sledge I used.
We use a hydraulic one at work that has a square bit made for driving sign post stubs. SOOOOOO much nicer than the ole sledge method.
Depends on the soil type, but you can usually set them with water. Dig a small hole, keep water standing in it, work the rod up and down. I can normally get all but a couple of feet in and then finish with the hammer.
I have always been told.   Don't fight it just get a bigger hammer .
Wish I had pictures, 15-18 yrs ago I used the hyd hammer on an excavator to drive a bucket pin out on another excavator I needed to swap buckets on.
Best part was it was only seized in the last bit of bore, so once the pin let loose, it must have flown 40 ft.
  • Confused 2
Good thing nobody was within that 40'
Young and dumb & what happened on night shift... stayed on night shift.
I was smart enough to make sure no one was around to get hurt.... or see me do it!
1 hour ago, Cattech said:
.. or see me do it!
Most important part.
I have seen those hanging from floor joists, while cutting holes for duct work in concrete basement walls.
Cameras all around the shop at work now. 🙁
