Lt.513-2
Farmall Regular Road Gear
I bought Behlen road gear model R101 for my f20. Found out the road gear will not work. The top shaft is too small for the road gear. I was thinking it needed an adapter for the top shaft but I was wrong. Can anyone shed some light on the top shaft of the f20 on the correct road gear. Does the f20 top shaft need to be drilled and tapped for the correct top gear and the adapter that goes with it ? Also willing to trade for the correct road gear complete. This road gear is complete and cleaned up. Gaskets are all made up. Missing 1 cover bolt , easily obtained. I’ll look to see if I can find it. Pm with any questions
     Thanks Jason
