1086 front engine seal
gafarm49
I would suggest replacing the oil pump also unless you've done it already and take a good look at the front damper too while your there
Many of those seeped when new so had to be change.
Pry out the old and tap in the new.
A new seal and wear sleeve on the damper and it was fixed.
