EDWARD886 Posted June 6, 2018 Share Posted June 6, 2018 NEED SOME HELP/SUGGESTIONS ON TURBOING A NEUSS 358 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted June 6, 2018 Share Posted June 6, 2018 To run in what class? I'd suspect that you will run into competitors with more cubes and a lot more hp.in the same bracket. Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted June 7, 2018 Author Share Posted June 7, 2018 That’s the problem I’m guessing it will be cheaper to put a dt466 in her? Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted June 7, 2018 Author Share Posted June 7, 2018 Just starting out, right now I’m in the 10-12,000 lbs class stock but.... it’s not fast enough and not enough power... Quote Link to comment Share on other sites More sharing options...
stronger800 Posted June 7, 2018 Share Posted June 7, 2018 Local guy tried pulling a 856 (407) a few years ago with a larger than normal turbo and the pump tuned up. He sold it and boghtba 1066, turning that into a 466 this year i believe Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted June 8, 2018 Share Posted June 8, 2018 I did thay many years ago. Turned the 826 into a nice 130 hp tractor. I found a M&W set up and put on it. It wasnt all that expensive. BUT, in a tractor pull you will be outclassed. The 400 series engines are so easy to build HP. They have a much better torque curve and cubic inches matter. If you want to pull find a 1066 and start with that. With all stock parts you can get to 200hp. Pletny of room to improve from there. The little 358 is just limited. This is my 466 Quote Link to comment Share on other sites More sharing options...
redneckchevy9 Posted June 8, 2018 Share Posted June 8, 2018 5 hours ago, billonthefarm said: I did thay many years ago. Turned the 826 into a nice 130 hp tractor. I found a M&W set up and put on it. It wasnt all that expensive. BUT, in a tractor pull you will be outclassed. The 400 series engines are so easy to build HP. They have a much better torque curve and cubic inches matter. If you want to pull find a 1066 and start with that. With all stock parts you can get to 200hp. Pletny of room to improve from there. The little 358 is just limited. This is my 466 a wise man once told me... 1 Quote Link to comment Share on other sites More sharing options...
EDWARD886 Posted June 9, 2018 Author Share Posted June 9, 2018 On 6/8/2018 at 9:07 AM, billonthefarm said: I did thay many years ago. Turned the 826 into a nice 130 hp tractor. I found a M&W set up and put on it. It wasnt all that expensive. BUT, in a tractor pull you will be outclassed. The 400 series engines are so easy to build HP. They have a much better torque curve and cubic inches matter. If you want to pull find a 1066 and start with that. With all stock parts you can get to 200hp. Pletny of room to improve from there. The little 358 is just limited. This is my 466 That is sooooo nice, sounds really good Quote Link to comment Share on other sites More sharing options...
Pete1468 Posted June 11, 2018 Share Posted June 11, 2018 Years ago I saw a 756 German that had an inline pump and a custom turbo set up whopping up in the smaller classes. I should have taken time to talk to him but didn't. He was running with the 4020's with 466s and staying with them. Quote Link to comment Share on other sites More sharing options...
Thesd5488 Posted June 14, 2018 Share Posted June 14, 2018 On 6/11/2018 at 7:02 AM, Pete1468 said: Years ago I saw a 756 German that had an inline pump and a custom turbo set up whopping up in the smaller classes. I should have taken time to talk to him but didn't. He was running with the 4020's with 466s and staying with them. I remember that one it ran hard Quote Link to comment Share on other sites More sharing options...
fredcruiserman Posted August 25, 2018 Share Posted August 25, 2018 A mate of mine run a 1246 with a neuss DT 358 with a inline pump it devolps well over 800hp and goes quiet well Quote Link to comment Share on other sites More sharing options...
Thesd5488 Posted August 31, 2018 Share Posted August 31, 2018 On 8/25/2018 at 4:35 AM, fredcruiserman said: A mate of mine run a 1246 with a neuss DT 358 with a inline pump it devolps well over 800hp and goes quiet well That’s good for that but problem is that’s what it takes to pull stock around here I know of a 1466 with 15 mil pump in stock watched a 856 pull high 2 in 11700 and just keep pull the throttle as he needed more 7mph speed so he couldn’t open it till it would spin Quote Link to comment Share on other sites More sharing options...
