Michael Halsall
560 vs 660 engines
I am asking about the difference of the engines used in the 560 & 660 tractors.
The C-263 & D-282 engines as used in the 560 tractors were rated at 1,800 RPM
The same engines in the 660 tractors were rated at 2,400 RPM.
How was this achieved?   I assume the 660 Diesel had a differently rated injection pump.
How did the gasoline and LPG engines achieve this?  A different cam grind?
Regards from Michael H.B)
I think they just cranked up the governor on the gas and lpg tractors. The diesels had a different pump.Most 560's around here were turning well over 2 grand, our 660 diesel ran at 3000 RPM for 20 years.
Huh ? 3000 rpm you sure ? ours was 2400 rpm
Off the showroom floor the 660 was rated at 2,400 RPM. I assume yours was "tweaked up" by the dealer or yourself to get a bit of extra power. By squeezing extra power out of a 660 it could be used to pull even heavier implements, an advantage with a wheat land tractor!
Regards from Michael H.😎
that's a gutsy call rev'ing them 282's up like that considering their history of head gasket failure let alone getting 20 yrs out of it amazing
282's in trucks were running up to 3200 at the time according to our IH guy so we figured what the heck and cranked her up! Every other one around here ran hot and blew up, ours kept cool and never missed a beat. Took the hard surfacing off third gear pulling 30 feet of discer for ten seasons before demoting her to second tractor after we got a 125 Versatile.
in the trucks high rpms were short periods on a farm tractor full throddle rpm for long hard pulling really is pushing the limits I would have opted to install a turbo an kept the factory engine speeds
I assume the turbo adds mid range power rather than raising the RPM range. Having said that turbochargers generate heat and add pressure to head gaskets etc.
There was a turbo version of the D-282 diesel (DT-282) used in the TD-9B crawler tractor. I know nothing about it but I assume there were some internal modifications made to this engine to cope with the turbocharging.
One of the things you have to remember about the C263 and D282 is they have a hugely overdesigned crankshaft and connecting rods. I have seen a D282 come out of an 8500 hour model Farmall 706 and when checked out we were able to use standard rod and main bearings. The originals were still ok and only starting to get into the copper. You could say, "how can that be?". What you should remember is that this engine was originally designed for ungoverned motor trucks and people would often rev them up to or over 5000 RPM before shifting into the next higher gear. Above that you start to get valve float. That is also why they were one of the preferred engines for tractor pulling. As a six cylinder engine they were balanced for both primary and secondary forces and couples. That was one of the attractions for IH using them as tractor engines in that they run smoothly. The block was also fully skirted which added rigidity to the lower crank case area. The weakness was the number of bolts used to clamp the cylinder head and that is because it was originally designed as a gasoline engine. The lack of sufficient cylinder head bolts was the problem the designers encountered when they first tried to dieselize this engine back in 1954. It took considerable ingenuity to overcome this problem through redesigned cylinder head gaskets and other changes they made later.
The same logic was successfully used later in the design of the 300 and 400 engines. While they were not used in trucks right away back in 1971 they were soon adapted to trucks in 1975. The earlier 361 and 407 engines were not used in trucks. Similarly the Neuss six cylinder engines were used in a few truck applications in Australia but as noted on this forum they were not very successful. Even the Cummins 8.3 doesn't have high reving capability built into it.
The original BD264 truck engine, BD meaning Black Diamond, were **** for tough all right. Their only weakness was dropping valve heads. A combination of over revving and heating would break the weld between the valve stem and the valve head with catastrophic results. The 220 and the 240 shared the problem.
My uncle said ' .... for stout'.
That just blows my mind that you could Rev them to 5000 RPM.
I have a pair of R-190's with RD-406's in them, that I used for hauling a TD-14A around "back in the day."
Just for fun I unhooked the governor, (set @ 2700), one day, just to see what would happen.
Well, that engine would pull it's butt off, way to the far side of 4000, (think 4500 to 4700), and not even sound like it was working hard.   :o
(In fact it sounded sweeeeet)
It didn't take long to re-think that plan, and re-hook the governor.
There was also the D301. The sleeveless version of the D282
Our 660 pulled 44 feet of cable-hitch IH rod weeder in 3rd gear with shop-built dual wheels, With manual depth control she would lift the front wheels a foot off the ground in the hard spots. The TA got a working over! Took the hard surfacing off the 3rd gear slider.
With modified to over 400cid with a billet crank and a filled and heavily ported 282 cylinder head it would rev to 6700rpm😂.  This was my dad pulling years ago and probably the highest rpm recorded video that we have on my channel.
Geez! Guys said we were nuts running our 660 up to 3000 RPM! Trucks spun then up to 3200 regularly.
I believe the 660 pump has an advance system the others do not have, or maybe it has more advance , I am relying on 60 year old memories here!
The 560 had a load sensing advance, or light load advance, same as the 656. The 706(282) used a speed advance in it's pump. It seems to me the 660 also used the speed advance, but I'd have to look up a spec.
