hillbillyhim
450 air pipe
Not unless some of the last M tractors made. M air cleaner outlet and pipe until near carburetor was a little smaller than a SM trough 450.  Dave
Maybe I was mistaken, I thought you were wanting to know about pipe from air cleaner to carburetor. Inlet pipes are the same on some M and 450 anyway if not all. Some air intakes have a seam up and down pipe and some 450 have a pipe without a seam. Some tops went in the ID of pipe and I think most 450 tops went on the OD. IH usually had 2 suppliers of air cleaners with some small differences between them. 400 and 450 openings for the ventilation line are a little higher on the intake pipe than a M through SMTA.
3 hours ago, hillbillyhim said:
Is the air intake pipe on a 450 the same as an M?
Nope,  I bought a 450 Donaldson precleaner for my M,  had to use a 2" to 2-1/4" sewer line rubber bushing sleeve inside the aircleaner base to get it tight on the inlet pipe of the M.
