T340 idlers
Before
3_CFCD75_D-_F691-4898-9_DA6-1_D72993599_
Bored, helical groove placed in bushings.
0_BA554_BC-_B32_F-4_D02-8_DAD-_B2_B738_D
A87_D1_A7_E-_EF39-4106-8608-2_D7_DFA60_C
B201_E770-0_A86-43_A9-942_C-61_DED87409_
Hand reamed and now to cut for seals on each end
566_D125_D-092_F-4_E8_C-_B2_F9-_AA9203_D
184_F17_F9-7933-4_BEE-_A6_A3-4_A12_E7_AF
basically all that can be done to repair them.
have you repaired /trued the guide/adjustment arms?
replaced the bellows seals with.....?
Guide arms are true
bellow seals will be replaced with similar seal to keep dirt out but the double lip spring seals will be doing the work of retaining oil
Nice work!! clean and professional - looks like fun and like it will work well. quick question - how were the slides on the adjusters? my slides were cut-off at one point and reweleded on and they are not properly aligned. I need to loos to see if track frame is bent.....winter project (not stating the YEAR of which winter, just saying "a" winter................)
Nice job, shop, and adjustable wrench ?... And Call Co. .
^ good eyes, that wrench is amazing
slides are good, I have a smattering if reasonable rollers
The only remaining issue is that the steering clutches have been done by a prior owner however turning right and less going uphill is still quite difficult.
It appears to of been a long-term problem as the right-hand turn and lever appears to have been welded at the angle with a gusset as it takes a significant amount of effort to try to turn it.
mmi had suggested looking at brakes so with uc off, will do that then go back to clutches
On 5/21/2018 at 6:01 AM, plastikosmd said:
Were the original bushings/bearings made of brass or steel ?
That is one **** of a mill and boring head!  MORE PICTURES OF IT PLEASE!
