superih Posted February 13, 2018 Share Posted February 13, 2018 Can you guys tell me if the feeder house size is the same between the 2366 and the 23/2588 combines? Do the heads interchange with out modification? 1666 I'm pretty sure was smaller than a 1688, that is why I'm asking. Link to comment Share on other sites More sharing options...
JessePeden Posted February 13, 2018 Share Posted February 13, 2018 All combine up to 25 series have same hook up no matter which model you have from 1420-2588 all newer 5088-9230 combines have bigger opening in feeder now the tricky part head wise all 1020 and older will fit all 2588 and older machines the 2020 (which I don’t recommend) and 3020 heads fits newer style combine but have adapter plates and shafts to fit older machine only catch with a 1020 is if been adapted for single point hook up/side latching which is what all new machines have ( a lot safer to hookup) I do not think are compatible unless combine is switched requires some welding to adapt same way with corn heads 1063 and older for 2588 and under but gets more interesting with new corn heads 2200 series are not loved around here by some but I think they can go either way with a plate i skipped from 1063 to 4206 so not much help with 22/2400 in the 3000/4000 series heads (newer style) any with a 2 for second number from the factory fit 25 and under and a 4 as second number fit new wide style feeder but the 32/4200 series can be adapted to fit newer styles and 34/4400 can be adapted to fit older ones above statement holds true till 2017 and now Case IH is making just 4400 series and selling adapter plate for older machines as I understand it sorry for long post but many options are out there with a lot of good older machines still available to interchange with older combines with newer heads are what we run mostly Link to comment Share on other sites More sharing options...
jass1660 Posted February 13, 2018 Share Posted February 13, 2018 The face plate that goes into the head is the same but the throat itself is wider on the 80 series versus the 40-60 series. Link to comment Share on other sites More sharing options...
dale560 Posted February 13, 2018 Share Posted February 13, 2018 60 series 24 inch rotor so chassis is adjusted to that size. 80 series 30 inch so sieve is wider ,one more auger sieve wider feeder wider. Link to comment Share on other sites More sharing options...
superih Posted February 13, 2018 Author Share Posted February 13, 2018 thanks guys. Link to comment Share on other sites More sharing options...
