Tilt steering
gafarm49
the NOS tilt kits must be awfully scarce by now.   you might be farther ahead to check with salvage yards and get one out of a  30 or 50 series that's been knocked in the head.  If your 10 is a TA delete it's a straight swap.  With a TA the main dash plate would have to be cut to accommodate the lever and relocate the rear flood light switch.   Mike Links at Triple R Tractor has the correct dash decal in that case as well.   And if you do take one out of a salvage tractor try to get the lower dash trim piece because it has the proper labeling for the lower row of switches
