5400 Soybean gear down kit
superih
18 hours ago, JimG said:
If your drill is a 5100 then you need 2- 815770c1  driven sprockets. I
think they are still available.
That is a good number, comes up as $105.00 each, so I would need two of those per drill and then longer chain, correct?
Thanks.
Thanks.
On my 510 it's a longer chain. The 7 Tooth is replaced with a 14 tooth. One per side simple job to switch
The chain is about 5 links longer and the 7 tooth sprocket is for regular grain and the 14 tooth is for soybeans.
These a driven sprockets so that slows the feed cups to half speed.
