Long Farms 1,764 Posted August 19, 2017 Share Posted August 19, 2017 New toy and fall project. 1 Quote Link to post Share on other sites
660 driver 802 Posted August 19, 2017 Share Posted August 19, 2017 Nice! Quote Link to post Share on other sites
redtop1460 9 Posted August 19, 2017 Share Posted August 19, 2017 Nice, that signs really cool too Quote Link to post Share on other sites
Farmer-78 0 Posted August 19, 2017 Share Posted August 19, 2017 Another nice find!! Quote Link to post Share on other sites
TP from Central PA 3,166 Posted August 19, 2017 Share Posted August 19, 2017 No PTO? Quote Link to post Share on other sites
Long Farms 1,764 Posted August 20, 2017 Author Share Posted August 20, 2017 Quote Link to post Share on other sites
INTERNATIONAL 1466 1,565 Posted August 20, 2017 Share Posted August 20, 2017 From the cold country? Heat houser bracket on the ole girl? Great find again sir. Gotta get the weights in the right place. Quote Link to post Share on other sites
234-IA 97 Posted August 20, 2017 Share Posted August 20, 2017 straight old girl. Never understood why IH went with 6 bolt hubs and 11Ls on those tractors, seems like most every 12 I've ever seen had 8 bolts Quote Link to post Share on other sites
Sledgehammer 7,435 Posted August 20, 2017 Share Posted August 20, 2017 Looks like a straight machine. 4 hours ago, TP from Central PA said: No PTO? X2? Quote Link to post Share on other sites
Long Farms 1,764 Posted August 20, 2017 Author Share Posted August 20, 2017 Factory PTO delete, 1 hyd. Quote Link to post Share on other sites
TroyDairy 1,489 Posted August 20, 2017 Share Posted August 20, 2017 This guy wont sell. Says bought it near new. 1 Quote Link to post Share on other sites
Long Farms 1,764 Posted August 20, 2017 Author Share Posted August 20, 2017 I want a 1456 with factory cab. 3 open stations does nothing for me. Want somthing different. Quote Link to post Share on other sites
74A-472 14 Posted August 20, 2017 Share Posted August 20, 2017 it is great to save the old girls of the past. this 1456 looks to have a chance to be a beautiful tractor again. I have a low hour 1456 that is wearing way better duds than your tractor. I just wish i had the money and get up and go to bring my 1456 up to the standard that you will end up with this tractor. I hope to see your 1456 on this site when you get done giving it a new lease on life. Quote Link to post Share on other sites
Long Farms 1,764 Posted August 20, 2017 Author Share Posted August 20, 2017 This 1456 originated from Munday TX area. The current owners dad bought it in 1980 and it was his big horse till his passing. The father past away a few years ago. Would have loved to sit in a coffee shop with him and hear the history and stories about it. Typical scenario. Son has cabed mfwd kubota with loader an old iron is just that to him. He had lots of memories of it but no desire to keep it. Thats where i step in. As bad as it needs paint i wont do it. Ill get it mechanically and electronically sound and set it up like i normally do. The 1456 will look and be more honest unpainted. Ill try a few things to bring the paint back a little but im not expecting much. Other than paint the owners father took care of this 1456. Only thing hacked up is the battery tray to fit a single HD battery which is typical. The sway limiter is a west tx style and he said all the factory take off parts are gone. Shows 7750 hrs and clutch pefal wear goes along with that. Front axle is tight and was kept greased. Fenders are in great shape other than umbrella and radio bracket holes. Shifters are decent but need to be tightened up. Needs new fuel/temo guage. only sheetmetal missing is battery covers and alt belt cover. TA works and the brakes lock up the tires. Brake pedals have very little wear. Of course it has those crappy longbar/short bar tires I hate almost as much as DT 710s. Hyd seat and accumulator work. I like the fact this one doesnt have the massive casted wheel weights. I didnt get it on the road but rear end whine wasnt that bad. The grille is immaculate and oil cooler and radiator was kept clean and in good shape. Heres the plan: Wash and degrease the tractor Remove west tx sway limiter and install correct factory limiters. Install pto delete plate Add 2nd hyd remote Add 8 bolt hubs and 10.00x16 front wheels. Set tires on 30" centers. 2 sets of wheel weights 12 hole weight bracket, full set of weights Add a damn muffler Install IH engine oil pressure gauge Get all the lights working. Add correct IH hyd seat cushions. (If anyone has a decent set of IH hyd seat cushions send me a PM. White or black will work.) Full service, all new fluids and filters. Fix all oil and fuel leaks. Quote Link to post Share on other sites
Long Farms 1,764 Posted August 27, 2017 Author Share Posted August 27, 2017 Quote Link to post Share on other sites
Alan Dinan 618 Posted August 27, 2017 Share Posted August 27, 2017 Nice find Brian, good luck with it Alan Quote Link to post Share on other sites
Long Farms 1,764 Posted August 28, 2017 Author Share Posted August 28, 2017 Not a fan of water in the tires 1 Quote Link to post Share on other sites
Sledgehammer 7,435 Posted August 28, 2017 Share Posted August 28, 2017 You won't have to worry about any grass there for 6 months or so. Were the valve stems mounted truly opposite like that or did you have to work at it? Quote Link to post Share on other sites
1480x3 362 Posted August 28, 2017 Share Posted August 28, 2017 3 minutes ago, Sledgehammer said: You won't have to worry about any grass there for 6 months or so. Were the valve stems mounted truly opposite like that or did you have to work at it? Grass might be OK, guys I worked for in Texas had an attachment for a garden hose to fill tires therefor they used straight water. Quote Link to post Share on other sites
Long Farms 1,764 Posted August 28, 2017 Author Share Posted August 28, 2017 Got lucky and both hit on bottom the same time. Im not sure what all yall put in tires up north but water and antifreeze lite wont even wilt the grass. Its August in TX anyways, that grass shouldnt be green now. Quote Link to post Share on other sites
iowaboy1965 2,350 Posted August 28, 2017 Share Posted August 28, 2017 49 minutes ago, Long Farms said: Got lucky and both hit on bottom the same time. Im not sure what all yall put in tires up north but water and antifreeze lite wont even wilt the grass. Its August in TX anyways, that grass shouldnt be green now. Calcium chloride and water Quote Link to post Share on other sites
stronger800 840 Posted August 28, 2017 Share Posted August 28, 2017 .....Yep, kills grass till next spring. But weeds will grow in the brown spot, in about a week. Quote Link to post Share on other sites
Sledgehammer 7,435 Posted August 28, 2017 Share Posted August 28, 2017 9 hours ago, iowaboy1965 said: Calcium chloride and water ^^yes 8 hours ago, stronger800 said: .....Yep, kills grass till next spring. But weeds will grow in the brown spot, in about a week. I guess I got a strong dose because it killed everything and stained the gravel. Quote Link to post Share on other sites
Matt Kirsch 889 Posted August 28, 2017 Share Posted August 28, 2017 I kinda figured it was straight water because otherwise no self-respecting kid would be standing under the stream like that. The CaCl solution I'm familiar with is generally brown and sticky, and God help ya if you get it in your eye. Who do I write the check out to when it's done? Or, maybe I should ask who should I have written the check out to BEFORE you got your mitts on it? I would probably forego my search for a Magnum if a field-ready 1456 popped up. Quote Link to post Share on other sites
Long Farms 1,764 Posted August 28, 2017 Author Share Posted August 28, 2017 Its in progress. I hope you like the front end set on 30" because i just spent 7 hours breaking it loose and narrowing it in. After i get the rear set in ive got 8 sets of wheel weights to put on. I put on some 7.50x18 6 bolt fronts for schitz and giggles. Ive got some 8 bolt 11L15s ready to put on but i want to end up with 10.00x16s. Hard finding good used tires. Quote Link to post Share on other sites
