H4 mag,,,timing of rotor gears
Service manual says to line up the "L" mark on the big gear with the mark on the small gear. The "L" mark is for counter clockwise rotation. If the mag is use in something with clockwise rotation, you use the "R" mark, but it says to use the "L".
George
on trucker1 advise I popped all 7 of my spare h4 mags apart to double check the timing marks. 2 were correct for diesel with CCW rotation, 1 was for CW rotation and 4 were way out in outer space on the timing. also note that only one shiney silver mag of the 3 mags I bought on ebay was timed for the diesel rotation. no wonder I would get mad and the cat won't start and toss the mag aside, then bolt another one on only to have the same problem. today all 7 parts mags are now timed correctly thansk to this BB and trucker1.
KoO
Hi KoO  Have  you checked the rotation of the impulse on the mags.  If some came off a gas engine depending the engine it was on it could have a different rotation, and it still may not work on your application.  Just a thought.
Cheers Russ
Here is a service manual for IH mags
GSS-5035 Service Manual Magnetos
Cheers Russ
that is ok, I have 2 gas motor cats int he Kingdom and learned a long time ago that the mags are different rotation. right now i'm learning all I can on mags so I become the King of Mags. plus everything will be done in house because i'm tired of buying rebuilt mags to find out they are timed wrong or don't work.
KoO
