case 585
my case 585 has a inline filter before the fuel filters no 1 is that allright no 2 should that plastic filter be clear full of fuel  or just running through it  as fuel is needed  also this tractor runs real good for a few min then starts missing  no 3  when you look into tank i see some air bubbles  no 4 can i blow back into my fuel tank with an air hose at the inline filter to make sure nothing is cloged in tank thanks for your time help is needed
clear filters do not always run full...simple enough to try a new one
will not hurt anything but PO must have suspected ......
most of those tanks and fittings need a through cleaning  and some draw from the non fill side so it looks like 1/2 full when you are out with cross over plugged   clean everything good, fill to 3/4 leave cap off and try   then tighten and confirm cap vent clean also
