mikem50 Posted November 19, 2016 Share Posted November 19, 2016 I parked it in the woods 15 years ago because it had a bad ring and pinion. Could not find parts. Recently I have ran across Reliable Aftermarket Parts out of Williamston MI. They had what I needed. I had to grab it and tow it to my shop. Once I got it inside I found the engine was locked. Finally have gone thru injectors,glowplugs and got it freed up. Next I will start the pinion removal. This is a 1962 model. Anyone ever done this ring and pinion job? Doesn't look like much fun. Took the shifter fork case off>> Oh well, I'm laid off for the winter,, it will keep me busy Quote Link to comment Share on other sites More sharing options...
AKwelder Posted November 19, 2016 Share Posted November 19, 2016 Looks like a nice size for driveways and a bit of snow. Never been in the gear boxes but changed a few cutting edges. Good luck and keep us posted Quote Link to comment Share on other sites More sharing options...
mikem50 Posted December 15, 2016 Author Share Posted December 15, 2016 It's done and running. Just tried it out on my one mile driveway with only 4 inches of snow. Working great! Needed a new thermostat,, Thanks out to "Yesterdays Tractor Co" for their fast service. Anyone out there that has put a block heater on a IH UD236? I'm wondering what type of electric block heater to use. Also thanks to "Weller Tractor Service" who helped with various parts needed. I'll post some photos once i get them shrunk down to proper size. Quote Link to comment Share on other sites More sharing options...
AKwelder Posted December 15, 2016 Share Posted December 15, 2016 Not sure on the block heater, when I did my 460 I researched the Kat's company and found their dealer here. They had a book with all the break downs, and a international sized model on the shelf http://www.fivestarmanufacturing.com/kat_s Quote Link to comment Share on other sites More sharing options...
AKwelder Posted December 15, 2016 Share Posted December 15, 2016 Looking onward to pictures Quote Link to comment Share on other sites More sharing options...
Rainman Posted December 15, 2016 Share Posted December 15, 2016 http://PhillipsandTemro.com makes Zerostart block heaters, etc. Listings for a D236 ... model heater #3100061 with 1 5/8" freeze plug opening on right side of block. They give specific location & direction of install. BUT I don't know if that is same engine as your UD236. Quote Link to comment Share on other sites More sharing options...
mikem50 Posted December 17, 2016 Author Share Posted December 17, 2016 Thanks Rainman and AKwelder, I'll get to work on that heater. I got some pics shrunk, so here goes Quote Link to comment Share on other sites More sharing options...
mikem50 Posted December 17, 2016 Author Share Posted December 17, 2016 Quote Link to comment Share on other sites More sharing options...
AKwelder Posted December 17, 2016 Share Posted December 17, 2016 Man that ole girl would be a sweat around here for snow and hard pack, thank you for the pictures Quote Link to comment Share on other sites More sharing options...
Sledgehammer Posted December 17, 2016 Share Posted December 17, 2016 With a machine like that you might get real popular with the neighbors looks nice Quote Link to comment Share on other sites More sharing options...
mikem50 Posted December 19, 2016 Author Share Posted December 19, 2016 Thanks Sledge, I sure had fun doing it. Of course,,, now I want snow, and don't have any.. I hope this summer to try to paint this old girl. I fixed it mostly for my grandsons after I'm gone. They will have a blast after they play with it a bit. Quote Link to comment Share on other sites More sharing options...
Rainman Posted December 20, 2016 Share Posted December 20, 2016 Army gave me AIT on Cat 12s & have run a Galion or 2. May want to acquire a set of chains if you do any heavy snow work. You're doing some serious maintenance on that rig. Keep us in the loop. Quote Link to comment Share on other sites More sharing options...
FarmallFan Posted December 22, 2016 Share Posted December 22, 2016 On 12/15/2016 at 0:02 PM, Rainman said: http://PhillipsandTemro.com makes Zerostart block heaters, etc. Listings for a D236 ... model heater #3100061 with 1 5/8" freeze plug opening on right side of block. They give specific location & direction of install. BUT I don't know if that is same engine as your UD236. Yes its the same engine. The UD designates it is a power unit. The block is the same. Quote Link to comment Share on other sites More sharing options...
Rainman Posted December 22, 2016 Share Posted December 22, 2016 22 minutes ago, FarmallFan said: Yes its the same engine. The UD designates it is a power unit. The block is the same. Thanks BJ, for updating my doubting mind........Merry Christmas! Quote Link to comment Share on other sites More sharing options...
mikem50 Posted December 24, 2016 Author Share Posted December 24, 2016 Thanks Rainman ! Quote Link to comment Share on other sites More sharing options...
mikem50 Posted January 5, 2017 Author Share Posted January 5, 2017 I got that Block Heater thanks to Rainman and Farmallfan. It was simple to install. I just wanted you guys to know what my tests did. >> After install I thought it best to see the performance of this heater. I had 22 degrees outside. Inside I used a heat gun probe Before i plugged in it was 34 degrees. In one hour it was 64 at the block and head. I tested the next hour and it was 81. The next hour it was 94. I suspect 3 hours are best if you have a timer. The fourth hour was 96. ,,, not much gain.. Hey AKwelder,, send snow down please. Quote Link to comment Share on other sites More sharing options...
AKwelder Posted January 7, 2017 Share Posted January 7, 2017 On 1/5/2017 at 4:09 PM, mikem50 said: I got that Block Heater thanks to Rainman and Farmallfan. It was simple to install. I just wanted you guys to know what my tests did. >> After install I thought it best to see the performance of this heater. I had 22 degrees outside. Inside I used a heat gun probe Before i plugged in it was 34 degrees. In one hour it was 64 at the block and head. I tested the next hour and it was 81. The next hour it was 94. I suspect 3 hours are best if you have a timer. The fourth hour was 96. ,,, not much gain.. Hey AKwelder,, send snow down please. Deal, been visiting my parents and the wife's relatives for the holidays but we got over 15 inches while I have been gone. Quote Link to comment Share on other sites More sharing options...
