76-140
1952 Farmall M
Here some pictures of my new 1952 Farmall M.  Hopefully yall can keep me going in the right direction and give help as needed with this project.
Is it a super m? If it is should have a c264 cast into the block near the oil filter canister, either that or its one of the handful of straight Ms that got disc brakes the serial # should tell u what it is. Nice looking rig
One of the last M's.  The block does not have 264 cast into it but it does have the big journal crank with a 4" bore.  Disc brakes, but still has the belly pump for hydraulics.
Habit of mine if I see disc brakes I gotta question it?? Not all super m have live hydraulics (SMTAs do) I have a 53 SM that has a belly pump and the battery under the seat, are u building a workhorse or a show tractor?
This tractor belonged to my uncle who passed away a couple of years ago.  The plan is to fix the engine, as it has spun a rod bearing and apply a fresh coat of paint.  Its funny some of the things that IH did around transition years.  My father has an early Super M with belly pump and battery under the gas tank.  Basically the same tractor as this one.
She looks like a good start. Much nicer out of the gate than my 50 M was.
Here are a few of my 50 M in work.
Nice looking tractor you got there.
Our super M has belly pump and battery under gas tank.
