T6 Restoration Pictures
  • 2 months later...
  • 5 months later...
Got bushings for the rollers, idlers, and carrier rollers . The shafts have been spray welded and returned to their original 1.5 dimension, and I found a company that can cut all of the felt components that go in the rollers and idlers , they will be arriving shortly !
Shafts look good..... Where did you source the bushings ?
4 hours ago, td-18 said:
And I got the new felt parts today
Are you able to share where you sourced you bushings and felts ?
On 4/4/2019 at 9:29 PM, td-18 said:
I had the bushings made at American sleeve bearing and a company called Sutherland felt company did the felts
Thanks !!
  • 2 months later...
TD18,
 Not sure I will ever do ( refurb, clean and paint) one of these old machines, but it is sure nice to see your detailed work on a machine similar to mine. Keep at it! Paint, then assembly, your getting closer to the finish!
Regards,
 Chris
td-18,
Just awesome! I am in same stages on my orange project tractor. I seen the corks which are correct in these I believe because my TD6 still has them in there. But as I refub some projects it would be nice to have a couple dozen corks of various sizes to plug holes for painting! Not sure how expensive corks are now days. Maybe hobby stores or on line??
Anyway your under carriage is going to look great and function as new! That would be real nice to not have to worry about running a track off and having all the adjustments and things working as they should! But then there almost too nice to go out and do work!:!
Regards,
Chris
td-18,
 Thanks for the nice shots of the track support guides painted in primer. Almost makes the job look possible! Do you use a forklift or a crane for the lifting? That is going to be almost too nice to use to push dirt!
Regards,
 Chris
td-18,
WAIT! you have two or three more of these waiting in the wings too? Wow! Nice collection! Those cherry pickers do a nice job. I have one. Your track system is looking great! You got a really nice gloss to the paint. I always have a heck of a time with the paint part of these projects.
Regards,
 Chris
