47 cub paint
What paint code does everyone use for a 47 cub? If I read correctly, it should he IH #50 red. The body shop here uses RM but we couldn't find a code for it. I want to use a good paint that won't fade out fight away.
This is the only chart I could find for RM #50 which doesn't help much with years instead of RM codes. BASF "RM" may not have a formula for it im guessing!
post-114498-0-99424100-1459785437_thumb.
BASF also has their cheaper line of paint called LIMCO and I know they have a "Harvester Red" that they can mix. Not sure if it even matches 2150 or 50 red...usually the cheaper the paint the worse the color match! Mike
