Ruby Red's IH Equipment at Work
Ruby Red
I always thought that IH should have had a F606, why not? Would have been a somewhat modernized F460 and probably would have had a good bit more power that the 504. I guess the real focus was on the 7 and 806.  You did a nice job of creating one!
2 hours ago, Rainman said:
Front mount for a 234 picker/sheller on your F606?
The front bracket on the 606 is a weight bracket, not used with picker, the bracket behind the engine and below clutch housing is for mounting the 234 picker. With the 221  6 cylinder engine this tractor comes alive, almost a 656
  • 3 weeks later...
Picking the Popcorn with B250,  1PR Picker and 100 Flare Box. Excellent crop this year, need to get it off cause squirrels are getting into it
Pretty cool stuff!
Some nice crop, most cobs 9" long
What can I say, I do not have the words. If  heaven is not a lot like farming I do not want to go. Very good looking soil you have there. Nice looking toys. And I hope you have a good long healthy  life to play with your toys.
Grandsons Dustin and Jake shelling popcorn with 782D pulling sheller
582 Special on sheller, 782 with 2250 Loader hauling the corn in 100 Flare box on C9A  IH Wagon
Combined the Soybeans in the garden, with the 93, good yield on 36" rows
Really enjoy your collection and you live  really close we will have to talk sometime
10 hours ago, nate said:
Very nice pictures.   I really like the 782 with loader and flare box.   How is the canopy mounted?
The canopy is bolted with four 1/2" x 1" bolts from the bottom of fender up. When I build the roll bar, I made up cover plates, drilled, threaded, and welded another set of cage nuts to the plates then welded the plates to the posts with threads turned up inside. Also made up support gussetts  under the fenders, covering most of the under side of the fender then down and bolted on to the main channel frame rail - very secure.
All that 782 needs is a cab and it would be an identical mini me to my 3688 and 2355 loader.  I assume you painted the loader.  Anyway, it is sharp!  Like to find a loader like that for my 682 cadet.  I'm in awe of your line of equipment!  Wife and are planning a trip to Niagra faalls in the next couple years.  Might have to swing into Cannada and have a look at your stuff.  It is basically closer to come your way that stay in the states from Northern Indiana.
jerry
Combined the corn today with the 815 - crop not as good this year as some, fought with weeds and lack of rain, good thing have some with 19.4% moisture, sure helps on the drying charges and flows out of wagons and truck nice
Hauled all the beans and corn with the 1500, sure cut down on my road time, now we can get the painting finished on the cab
 All I can say is WOW ! You're a show all to your self.
   Congratulations  on being able to accomplish this tremendous tribute to I.H. and viewing for all I.H. enthusiasts
      Tony.
Corn is off, time to haul some liquid manure with Snoopy Jr. and 1/2 scale IH #1400 Spreader
empty
682 Farmall on liquid hauling, Snoopy needs to go pulling the plow
