Posts posted by 560Dennis
On 11/6/2020 at 5:47 AM, Piero said:
What i notice here seems to corroborate what you say 560Dennis.... as i'm finding that some parts that were looser immediately after the dunking are now harder to move. Makes me nervous.... !? If it'd be spring or summer still, that wouldn't be a problem, but with winter at the doorsteps i'll just have to hope for the best !!!
Keep your steam up as the the old timers say ❗️Don’t give up , it a blessing in disguise ? You will be enriched with the educational experience , always be positive about it . I find it’s good to set back and think for a day or two when a dilemma arises( in my case it may be a month with my Fordson) . Of course we will try to answer you.
hug the wife for us ❗️?♂️? It’s only a Farmall M ⬅️ -
Give the baby a good crankcase cleaning and new oil filter , often.
Just now, 560Dennis said:15 hours ago, Tonyinca said:
11/11/20
John and I had many items to put back on baler before rolling it out of paint shop .
we got her together and she is home ready to receive several pallets of painted parts .tony
Get your straw hat ,long sleeve shirts ,hay hooks and gloves ready boys!
On 11/1/2020 at 12:07 PM, 560Dennis said:
Mike ❗️“Pouring it on”❗️?
I’m wondering do you use gps to ford the River ? How do pick the route ?
sorry don’t want to sideways the thread ,but it’s fascinating ?
Yep ❗️you proved, “We build them good in Farmall ❗️“
1
Sometimes every nut and bolt from top to bottom must be rotated ,etc.
19 hours ago, mike newman said:
...interesting.....lucky operator.....that could have been far worse than a stuck engine....
.......the RPM's the engine is turning at , at the moment of immersion is critical !!!....for example in a third world country where I worked , the exuberance of the local "drivers' following a exceptionally heavy rainstorm, destroyed three engines , in 3 ton Nissan/Toyota work trucks.. Some of the rods were so badly 'bent' , that they had to be hammered out of the blocks...In event all the engines were scrapped....
So, the old "M" might have been turning over at maybe 1000 RPM....at the time of immersion....but as Lance suggested, the electrics would have quit...about a part second or so before the air cleaner top took water.......if the rotary slasher was still engaged at that point, that ''inertia'' would have kept the engine turning ..untill...it ingested that water in #2 cylinder......The fan blades...made of American steel, would not have time or inertia to ''curl' into the radiator. .thus destroying it....as do the bloody plastic fan blades...
I would doubt that a big end bearing would be the issue.....if by chance it proves to be that.....it would suggest the bearing and journal had long since lost that first flush of youth.....just my opinion....
I guess you are only going to find the real issue..upon pulling it down......I know that is obvious, but it is hard to second guess the real issue,,, My son and a grandson were being bloody stupid with neighbours 3 ton Mazda 'tipper''...went through our river crossing without checking the aircleaner/intake etc As it was set low on the passenger side of the cab....that little exercise cost 5K....
... I actually got the thing running....sort of....after a lot of vitriol /effort and time....that was good enough to drive onto a 'salvage vehicle. On pulling the engine down....one of the pistons had part of the top and the skirt broken......Engine scrapped. ...good luck !!
We have fun with river crossing where I live......
Mike
1
7 hours ago, Tonyinca said:
You know , I am amazed at what I see and hear as it pertains to rust repairs on these binders
my Dad had his IH pick up 7 years and beat the **** out of it but don’t remember a hint of rust on any of his pickups , I realize we are in Cali . But fast forward in this case 55 years and my RedKid same age a native Arizona all of life and this current project Herbie ,Central Ca all of it life and yet both had severe enough rust on floor pans , passenger rocker panel , both lower corners of windshield , and dash vents
pretty much same on both other then Herbie needed another hood because hinge pads were beyond repair from rust.
I follow these trucks on several IH truck blogs and they are severely plagued by rust . Yet metal and frame are Heavy gauge .
I H must of put no effort into rust protection thinking heavy metal was enough.
of coarse at 55 years of age I think all makes are suffering rust and corrosion, although I might say my IH baler project is about same age and it’s very heavy metal yet the corrosion build up at any junction of two pieces touching is more then I have ever seen on other old equipment .tony
All the more important that your preservation continues .
1
3 hours ago, Tonyinca said:
It’s was bought new here in Fresno and it spent its life being Herb’s daily driver and chase parts for his blacksmith business . Grandson drove it a few years in central calif .
yet , there was rust cancer on passenger floor , less on drivers side but still need attention . Dash had rust damage at corners’ and vent areas.
hood hinge mounts were rust damage beyond repair , had to buy another hood.so even in this dry environment it still had considerable rust damage
tony
I remember the Scouts and tavellalls that were sold at Jenks ih in West Springfield pa. They were very beautiful vehicles ,and I did desire one ,but dare not spend the high cost for one ,my reward would be they were totally rusted out in two years ! ?♂️Pitty ,always remember that !
only thing left was the frame and the roof in this climate.
shame , I don’t get it how they used inferior steel or skimped on the rust prevention for customers. Must have been a down fall for them . I sure stayed away .
my thoughts
1
That trucks never been in northeast Ohio
1
1
Just curious did the worm gear in your steering have much backlash ? Like lot of free motion in the steering wheel.
I’d remove the spark plug and attach a wet dry vacuum to each cylinder . Attached to air cleaner. Attached t to exhaust .
put some marvel mysteries oil in cylinders . Hand crank After your sure all water is out. Hand crank with valve cover off ,make sure clearness is right watch valve move up and down oil them.drain water ouT of Governor.
take your time you willGet IT going just don’t rush , hand crank I’ll you sure it’s free, can’t assume anythingvacuum magneto spray contact cleaner on points
drain generator .and starter
sorry got in late but posting anyway
1
4 hours ago, Frank H said:
It runs great now but a bunch of loose ends now. I had a Chinese marvel schebler carb knockoff laying around that works well, but i ordered a rebuild kit for the original zenith carburetor and will get that on eventually. The governor is sluggish and doesn't rev out, plus it gets to surging under load so I got a spring for a super c and a new gasket. I imagine it's all sticky inside. Also, won't start with the crank or 6v battery, but fires right up when tugged so I guess the impulse is sticky. Sitting is worse than running for sure.
It’s all the little bitty things that make these tractors come alive , keep ? looking
Keep it up ,keep us posted
1
Just notice is there a dust cover below the magneto? Or is it block casting?
That’s the hot set up !
1
What is the number on the block by the oil filter ? Part number of block
also over mag ? C113 oR C123 -
12 hours ago, nepoweshiekfarmalls said:
I have my Uncles 82, but have never used it. It was his only combine for soybeans and oats. He picked ear corn for his cattle.
Get out there ,tell me how she runs ,get some videos too
FarmAll down the pond. . . !
in Projects, Builds, & Restorations
Posted
Thank for your response !
