560Dennis
Everything posted by 560Dennis
  1. Nice stands fellows ,good ideas shared here!
  2. Yesterday ,I installed the tune up magneto on the Farmall C .Installed charge up battery. After that I in stalled the rebuilt generator wire it and polarized it. I started it with the rebuilt starter. Whirled it over and it fired like it always does. Very happy Farmall C man ! Went into the house to warm up cold fingers . Maybe adjust the valves and adjust the Governor control rods if I want !
  3. Don’t watch them much , only Machinery Pete Guess I’m a dinosaur
  4. My wife’s a good cook, made salmon fritters tonight. I ate Eight of them . i know she could beat Bobby flay . I ain’t bragging. Doesnt have every spice that drenches and McCormick has in it either Her
  5. Tracy Pannbacker did work for me , CLASSIC TANK AND RADIATOR REPAIR 614 S PARK ST, GIFFORD, IL 61847 CLASSICGASTANKANDRADIATOR.COM Primary Contact Tracy Pannbacker 217-568-7234 EMAIL COMPANY He would someone to give a call his add was in red power magazine.
  6. Got this from Messicks archives 10 8295D Part # 8295D Notes:FRONT WHEEL (For 7.50 x 16 tire)
  7. I might have ! Ha ha ,don’t remember . I like the bag s the best if I can keep them from pulling out on good days . Made so much three years ago ,have not tapped .
  8. Same with history channel
  9. Did one for the 560 D . Was so over built . Had one inch screws for leveling the tractor for alignment of bell hosing to the engine to re assembly . Did it cause I had a gravel shed floor.
  10. my C does that on me going up hills cause I refuse (to lazy) to put enough gas in the tank . Works fine going down hills .
  11. Suggest staying with original set up( generator)+ . Voltage regulator should have two coils one being a cut out ,the other being the voltage regulator . Suggest a reliable auto electric shop that’s been in business for awhile that knows your generator. Not saying you can’t rebuild it yourself if you have the machine tools, growlers,vom to test and repair . Have the Generator shop test your unit before you do anything . You might be ok , could be an another issue , this will save u about 200 . Suggest getting books out of libraries references read up on generators . Will help making the correct discision for you. i think an alternator is over kill for me. . Got one ( 6 volt converted positive ground ) on the Super C , it oks ! Not going to do anymore. Good luck
  12. Many people put a pee ! That why it grew to larger?
  13. https://pittsburgh.craigslist.org/grd/d/ruffs-dale-farm-tractor-parts-ih/7703094154.html
  14. Check on a wild burro hunch Charley Burgh of http://www.burghimplement.com been the salvage business since the 30 s im assumes it is the injection pumps ? Heritage Diesel ,he on here( injectEd ) There a place In Boise,Idaho ??? Sorry don’t remember who ! Deal with a lot ofcTD tractors parts
  15. Went out to the garage (38F) . Set the new points gap to .013 on the H4 magneto for the Farmall C. Assembly of back cover . Assembly of the condenser cover. Installed and dated new rotor and distribution cap. Put on new and dated the new coil cover . Fingers got cold and returned to house , that’s enough for toady , got a lot accomplished! Rewards : Two brownies and glass of 2 % milk .
  16. I believe I read that the engine is the same as an MD if you need engine stuff , my collaboration.
  17. Isn’t there a filter or resistor on the rack by the bulbs ? I don’t never done one , good luck 🍀
  18. Fell on the ice testing the antifreeze in the C’s . Got up , finished ✅ . Elbow started stinging after I came inside. I had the wife check it out . Got a brush burn on it. Im lucky ,thank the lord .!
  19. I got my custom pistons for the Fordson from Wisco in mentor ,Ohio, ref. They looked at my piston , said it was a of a custom pistons similar to a tractor puller wanted them to make special. They told him his design would not work but he insisted . It didn’t work . To my advantage they made my pistons to our spec mine with a flat top . Also ,prior to this I went to Egge in California , they wanted to charge me double the price that Wisco did the job . They really gave the impression they weren’t interested.
  20. Story ! background . when we got the Super C in 1960 , it was a mess ,was used in the woods for logging , tree fell on it split in two . Weld back together . We got it cause it was a SUPER C , My first mechanic apprentice jobs dad gave (age 10 ) was to get huge plugs that they jammed into the cylinders 2 and 3 . The two horse traders we got the tractor from joked they couldn’t the plugs out of it . I think it was a joke on dad they wanted to play by selling it to us. because they knew dad wanted one. I think the hex on these plugs were 15/16 ( maybe you guys know what the hex was ion some 18 mm .or something I don’t remember . I remember there was no room between head and plug hex I got them out, think I use a in wrench toolbox . It would move the plug a 5 degree rotation . I spent a week some thing to get those plugs out. Anyways the tractor good for forty years after that. I should have saved those two plugs ,they would be priceless ,maybe wizards
