Posts posted by 560Dennis
I’ll be coming with Jean (wife ),taking Farmall C and C221 mounted corn planter ! Staying in champagne.
Stop by and say hello !
Can’t miss this to many good memories from redpower !
1
8 hours ago, Bgriffin856 said:
I'm not sure exactly what or if that is what it was. I just remember that they had a short long on it turning into a blade that peeled a thin sheet of wood off it as the log rotated
Got veneer lathe at National thrashers show in Wauseon ,Ohio third week in June
Usally , it next year ?
7 hours ago, Bgriffin856 said:
I remember going to this show once or twice about 20 years ago. It has a little bit of everything that is for sure and do a lot of working demonstrations. Do they still do the veneer mill?
Veneer mill ?
had Farmall a hooked to the shingle mill .
wasn’t paying attention,just briefly watching the saw mill -
Close up today with heavy tractors 6000 to 13000 classes .
I made it into all the parades.Took a few more photos ,got our Fordson and the Farmall C
Got a picture of Sugamaker 32 ford also
Got how pretty tired 4 hours just going and coming with two tractors .
shower and something to eat and relaxlistening to the rain
7
5 hours ago, Doug in NY said:
this looks like a winch
Add a comment to oil field maintenance , what missing is the derick and weight on front to hold the H from coming over. This a not too common set up , a small contractor. Big contractors used Cats , heavy duty . That h I personally don’t think it would hold up under the loads ,just my opinion , that y you don’t see many .
My friend in the business( Small) ,they had 8 Fordsons with winch’s ,they would use moving from wells they maintained.
where I got my information.-
2
All the Fords 8 n s linked , Russ son was driving jubilee leading on the parade route .
8 hours ago, AngrySailor said:
Yeah that’s normal. Better than having no spares! We have several exhaust valves and cylinder heads which are a more common failure but ships are required to maintain stock of “critical spares” and a liner and piston is on that list. Usually these engines are in a rotation of every three years change/inspect pistons and liners and we usually do two units per year to make that happen. It’s a lot of space and weight to carry a full set also. These slow speed engines usually give plenty of warning and will run near beat to death... you can also run With non functional units, piston removed even.
Thanks for the explanation ! Help a landlover !
1
Had a good time at the show today in Seagertown. Got both the Farmall C and the Fordson into the parade . I had to run hard to get Fordson started and into the parade, last year because I wasn’t slow getting the C into position .C was first down the parade route.
They were featured John Deere but the other makes we’re well represented also .
linked in some photos for your edification and amusement. Didn’t take as many photos as movies .A lot to do and see. Take a few more tomorrow.-
9
On 7/18/2023 at 4:20 PM, AngrySailor said:
That would concern me ! The mfg. ( someone of unknown origin ) would put one spare piston on board . You’re not confident in your engine ,you put a spare piston to change out at sea . What about the other five ?
This common procedure?
Set me straight on this ?
Anybody going to this show in stoneboro pa ?
https://www.mercercountyantiquepower.org
I got another commitment have r miss it
Looks like a nice one
1 hour ago, AngrySailor said:
Might take you up on that sometime. Thanks. You got serious pistons in that, I remember your build. The modern ring package will hold up eat better also. Low tension to boot!
Just remembered ,my piston the ring gap groove is big (?) all I can remember, and ring is real close to dome if I recall
34 minutes ago, mmi said:
have 115 believe the fixed body is too long for the short models,as it needed reach back brackets for the H
Good to know ,thanks
1
9 hours ago, AngrySailor said:
Pretty sure normal bore is 4”
edit, the N Fordson’s were 4 1/8” I believe...
The one that came out of mine were 4.0375 oversized from rebuild engine exchange possibly. Reason I asked . I think I got one if you need it but I’m sure I wouldn’t use it , up to you
yep n we’re 4 1/8
I could not find pistons ,any ,a year of spun around , contact my engine builder ,he went to Sue at wiseco in Mentor. Got them made .08 over to match clean up. Vroom! , 2 years wasted , thunder !
Got .08 Hastings rings from Chevy v8 in it . I have 4 sets of rings come to think of it ,you can have if you need them if you go this route . V8 rings were 40 bucks cheaper than 4 cylinders . Dah we went that way. Reason I got four sets extra.the weeds I get into make me sneeze !
1
1
10 hours ago, AngrySailor said:
Ahhh think those have been posted before but the front one is a 1925 that my uncles restored in the early 90’s. The other is a 1926 that’s in nice shape and has a good rust patina. The 25 runs but could use an engine freshen, the 26 was bought with the pistons in a box. Don’t see any major issues with the engine. Got rings and misc parts for it to run some day. Planning on leaving it a patina tractor.
4.0375 pistons?
Does governor resist you if you try to change the carburetor rod speed by hand?
There was one on Farmall c in Craigslist in Rochester Minnesota last fall
1
I think there is a 115 .
6 hours ago, AngrySailor said:
So! what is the story on the twin Fordson s in the side photo . Holding out word on me ?
I have a Fordson and its incurable curiosity -
12 hours ago, AngrySailor said:
The road is pretty narrow at my place. I tagged my neighbour up the road and buddys shop. Was going to wreck the tires under the big sign today but the MSD quit!
Good for you
Seat hinge repair for Farmall C
in Technical IH Talk
Posted
The bushings in the seat are shot . Seat twist when I sit in it.
isn’t there a kits available to fix them ?
I haven’t looked yet cause I need to look around here, thought I saw some bushings in the shed .
