Redisright
    48
About Redisright
  • Birthday 06/29/1944
    Danville, Kentucky
    all IH and HYDROS
799 profile views
  1. Redisright
    574 lift
    The lift arms on my 574 seem to have a mind of their own. No matter how I move the levers the arms will not go down. If they go down after setting for a while, I start the engine and they go back up. What is my problem?
  2. Looking at purchasing a 7110. What should Iook for? Quick way to check powershift transmission? Any tips. Thanks
  3. I agree. I am going to part it out.
  4. Where is burnt tractor located? Do you know the price?
  5. Thanks Mike . I think I will part it out and look for another tractor. How much for it. 859-516-4690
  6. I can not get diff lock to release. I have unhooked hydraulic line so no pressure. Any help would be appreciated. Thanks
  7. I need help getting the rings on without cutting them. Also need help installing after they are on and not cutting them. Thanks
  8. Could you give me contact info on someone I could get to do it?
  9. How difficult is it to install hi lo clutches in a 5088 speed transmission after you get transmission out?
  10. Can anyone recommend a good rear view camera for farm tractor use?
  11. I can not get remote hydrauliuc levers to lock in float position on a 5088. Is there and adjustment for this?
  12. I am using a 1086 with a double action cyclinder trying to keep down pressure on a no till drill. It keeps leaking off and I have to reactivate it. Is there a problem with my remote valve or do I need some sort of check valve?
  13. Has anyone install guidance system on a 86 series tractor? How happy are you with it?
