Calendar
Everything posted by DWF
1977 it is. DWF
At least it has the cat style tracks, a lot of them, that vintage still had the old shovel style flat pad type tracks. I had 1973 Bantam that had the new style tracks and looked at buying a 690A John Deere same vintage that still had the old style undercarriage. DWF
like Hardtail says, ag tractors like Farmall MD or International WD6. DWF
I can't help you other than you would need measurements. They did use a 414 in late model H65's. Good to see you back on here again. DWF
I have a Dresser TD-9H dozer and run 10W oil in the hydraulics but the transmission has Shell oil like hy tran. I bought a 624G JD loader and the manual said to use HyGard in everything but the engine. I asked the shell dealer about using the oil I used in the TD-9 trany in the JD. He said no because the JD needs an additive in the oil otherwise it hurts the wet brakes, differential and hydraulics are common fluid on the JD. DWF
My TD-6 will not start, what haven't I tried?
DWF replied to Tracksbeatwheels's topic in Technical IH Talk
Says Oregon on his avatar. DWF -
I don't believe there is any way to get that info, a lot of that type of info no longer exists. DWF
- 233 replies
- 1
That's very near me where they are at, but I don't need either and not both for sure. DWF
You will have more speed with the bigger tires, but less power. Your jack looks like mine, have had it for years and have others in between but that orange one is the best. DWF
590D was the same as a Hitachi EX 150. The last truly built John Deere was a 690E in the mid 1990's. All 690's were John Deere designed. The 590D had a John Deere engine and the Hitachi had an Isuzu engine. DWF
Early 530's had a DT414 and later one have a DT 466 but both are rated about the same horse power. DWF
I had several older TD-9's, This was in about 1973 or so and was, if I remember right a 1950 TD-9. Sleeves needed to come out and we were using ready rod which kept breaking. Went to a shop and had a rod made and threaded out of much stronger steel. Sleeves still did not want to come out. I got some dry ice and put in the inside sleeve area and hot water in the block and they all came out fairly easy. Don't ask me any more info as it's beem too long for my memory. DWF
- 233 replies
- 1
Lulich Implement in Mason, Wi. Mostly NH they have some Kubota and short lines. Been in business since early 60'd selling Ford and NH then. DWF
Did White trucks have Diamond T and Reo and then combine them to Diamond Reo? Around 1974 I was looking for a new heavy tandem and got a price on a Diamond Reo and remember the sales person saying someone else had purchased Diamond Reo by that time. I ended up buying a not too old Ford LT9000 though. DWF
More like a 1950, definitely not a 1960. Might have some life in it, especially if it is a good runner. DWF
I know I had one like that, probably a loadstar F1800. I think it was a t64 maybe, anyway it went down and no parts available and ended up putting in a t36 I think, anyway, it was a more common transmission. DWF
When do you need a CDL Heavy (heavy equipment, Tractors ?)
DWF replied to dale560's topic in General Chat
Also the weight that enforcement goes by is the manufacturer's rating, not what you have it licensed for. DWF -
Lucky they had 2 mirrors. I drove trucks of that vintage that only had a small mirror on the drivers side. DWF
I used to haul wood in NE Minnesota. We hauled mostly like this (cross ways) unless we had longer logs 12' to 18', then length ways. On this truck they have to be for lumber as they are sorted. Pulp wood is usually smaller diameter. We had one mill that took tree length for a while, had to haul that on a semi trailer. I hauled with a truck and pup, but much smaller loads as we had different weight laws. DWF
I have never heard of or seen one from Case. I was just on Yesterday's Tractor Massey Harris- Massey Ferguson site and someone said they had a good Massey Ferguson skidder. I did remember a guy having one of them in NE Minnesota back in the 70's. Another rare machine that I don't know what became of. FWD
It would be a 1973. I believe it would be a D206 engine. TD7-E had the D239 engine. DWF
By the early 60's the construction equipment from IH was yellow. Federal Yellow is like the TD15-C in my AVATAR. DWF
