mmi
Calendar
Everything posted by mmi
here every kid that took engine shop needed 2-3 my days of walking ,acre for $2 (1-2x /mo to save $)are gone. handle, deck steel/bearing wheels are actually worth more. we use to ride scrap day and trade x- for y and or supplies. Now migs can fix that $5 look like 65-72 series ,real 3 hp and torque ,strap anything on for a blade, rpm at 2k up to 6" wouldn't need but 2 fills/hr. bought out the last parts warehouse in '93,have all tools and 3' of manuals. most parts now used 3x have 4-5 on back shelf......too good for scrap .BUT....no good for anything else. MUSEUM... maybe zozia or bermuda grass 10x/yr or union golf course FLAT green, EVERY morning, they are perfect pulsed cut next to a reel. otherwise real grass under 2" every 3 days once 100% dry. NEVER fertilize. WA .A...WA. A.. WA..A. WA.A.. I have low and lower hp/speed and need more gas than a 560. cant imagine what 0 oil and meth would do to one I only cut a 4" pass over 3"high and plug every 50' need shut down and raked out every 100' when wet.And thats ONLY possible with the full OPEN baffle . flood while doing this and vapor lock on hot days..scissors are faster. Yard MUST be power raked after dry. My DA 3.5 wheel design is SUUUPER safe. My bagger is a joke, if I dont roll over ,it holds 1 round of the yard, only 60 rounds to go, falls off, tears ,zipper clogged or worn out, AND !!! destroys every flower or shrub yard art ,on that side. If I am equipped with $$$ power drive ,stock NEW slicks and seed for the yard divots, arent 3.5 wheels and a counterweight GREAT. The "commercial" rear bag super fuel tankers 2.5 g where ALL gone here before '85/88 NOW when W put that same engine with actual throttle and governor, on the first commercial weed eaters in '76 you had something,until the bent drive shaft and govt did them in like the 5.7
Bull pion shaft bearing cage Cormick Wd9
mmi replied to Cormick Willem's topic in Projects, Builds, & Restorations
fiat pulled ALL the old # and NLA at stealer. looking for some old books,,......either H or M would be a good start,even if a new # -
I want the mowers,did 1000s of acres with those +- 3/4 throttle and 6" +, +- tank /hr when gas was gas clock or wind rope start,but toss the mid series wa wa in the front
VT debunk...... always found the front approach to include biting clawing and wing kick. net is better, and lasso /saddle for the geese
do I need to say............. for $4.5 K it was gone this morning !!! I do the think the 06 duomix with 38K has covered up issues for $20K and seeing whom is selling, it was < $10K and will be tossed for parts at $35K if the $20k is not met
most you would find is 404,this should have the shuttle and hd axle ,rode rough on govt work....? high # c-135 so parts are + - tough nla vs nLA for low 135 kind of a cheap 340 and Sc/200 marriage
short of a blueprint (detroit) 5.7/ 350, or 6.9 (28-34 mpg),a v8 diesel , by oil/govt mandate was NEVER any good .
We only got 3.8 " this week,only 1/2 the calves born in the water No, govt PC BS They cant (easy)auto spy/MS back door on this computer so not, PC mandates that "you" must be kept safe. All the isp/and sites have to comply with new "safe" handshakes when you open a site. Had issues here,where clock was never correct, BJ fixed some but said I needed new system, WHich there have been none to be had. Isp changed last week from 30 day country roll out,if I had not dumped history it would have stayed. HAve a call in next week to " "build" " order from china a business system. otherwise ALL china out of the box if you want v8 then 3 spd and 12" wheels. caudy art deco monitor, touch and camera etc $300 + dvdrw ONLY reads pentium (ex) 8 is out, but they are pushing 2-3. so obsolete before it arrives. if you want p 5-7 cant have a 1 t HDD only CHEAP sstd etc. $800+ in software just to do what this one did before MS attack.
in horse hitch/show era we rented the tractors and owned the vans
not 4x 4 and I dont have email to ask for at least 40 days in the era of $110K+ trucks what should it go for?
In theory would save $80 K and the ins too, but still need 4 x 4 dont own a trailer less than 'permanent " plate technically in time it would be usable to go back and get a new cdl,since all we have are now 'illegal"depending which Capone' you get.
Some of you were retaking tests etc. What is the latest illegal changes made? 4700 for sale here cheap/cheap for today. What should they be? International diesel toter truck 4700 , size below CDL (no special license to drive). Auto transmission . Bumper pull and also set up for 5th wheel in bed. Have seen ,normal in flat states #25K loads with just p/u. trailer is #14/18k gw so 2 tractors are ok....but... + trailer is #15/20K and all together is # 23+/27K I am thinking with the new "rules" they just want it gone? And now to graft $$$$ for bridges ,axles have to be 4' or more apart to count as 2........kinda makes 90% of the trailers obsolete ..?
common problem when removing with b gear still in or cross the # forward expect an m would work -
just think why are the alternatives "ILLEGAL" for peasants hunter and the elites/pacs have no trouble with pallets of it. we are in very low risk the "institutions" cost us $30K + so far this year,(that was taxed handsomely last year )so there will be very little income. a can in the south 40 would have made more sense
I would expect the cab to be euro no robots on road alone thing and bring along bad weather work area......but why not ride along as said
the 5-a is same from kb7 /red 450 recall lock lever for low/5 and have a dodge that needs one ,o/d is 1/2 tooth from rev at 65 been in a f-9 ,15 gears in no order,and h/l /d ,load/empty roll/pulling added 3 x to the clutching or not
be day light soon try to see if simply a line or gasket before call in $$$$
very helpful,to not over stay the offer thank you again
that was discussed here over the winter.......now finding it...... try RPM
need 2 9/16 bolts $7 everyone wanted + $7-14 for the 2-3 week mail could have been in the #45 $14 /3 day order but didnt see them fasternal said they would do the 500 mile /week transfer FOB store price, ONLY bc I called and asked.Still 15 m to pick up. kind of hard to fix anything with $200 shipping from 20 locations if at ALL. may as well settle in, as Putin will have better parts and logistics soon.
Should there be a (one) box to limit or turn off auto notification,linked to a comment/post I make? currently have to drive to a neighbors to get/send email and there are 100+ RPM trying to update otherwise working computer,with previous options/functions at minimum and obviously now, that is not OFF the shelf < $1600 Thank you
grubs/voles/moles etc forced up by the water table. here they are in the barn yard at 3pm or 50' behind mower looking for anything kicked up. in the hot months it is rt hawks on the various farms,every 4-5 yrs may be an eagle to. not likely,unless bird shot here. no profile unless near something wanted
generally it is the !!!!!! CORRUPT !!!!! judge sentencing (or family) and CORRUPT politicians that OWN/OPERATE said "prison"
Soooo Whom is doing ALL the driving,,? as in latest excuse for price GOUGE
wait until that is a faux run on the banks,and "they" force faux money. totally in your phone then chip, where it is taxed 50% to earn 60% to spend,when and where "they" say
