mmi
Everything posted by mmi
  1. As VT says no singles or vertical, no box store or home owner, dont even look at the specs < $4.5(unit alone) Beware the auto stuff,in that if you DONT need it ,bc not home there will still be a big fuel bill our elec just went .50 to over $1 kwh ($5-8/DAY) thats still way under $6-12/hr fuel and lp ng is not far behind. all of those will be faux rationed soon. Cousin just installed $40K solar system,building upgrade to carry + 4# load ,and $10K ,(50K /cf ng allotment), backup. net meter/ cut rate pay that will go to nothing. 30 years + payback to my pencil, but he gets a lot of $ govt (pc green) kick back on rr pension.
  2. in the "hatted" areas they are concealed in groves or little shacks with message recorders. Some have "church" owned cells and autos consigned to the peon driver.at $150/day
  3. Cousin had a ranch and river crossing,in the (pre) park,wish we knew more about it...?
  4. mmi
    Wow, land
    thats nothing here, once developer steals if for $2-10K ac,due to taxed to death. it is sold for $50k ac or $100K with 75% govt $ improvements and must build a $400K + RYAn "starter " shack. All while paying $0 to $100 ac tax, After There was a quashed blow up of new owners tax bill of 65-130% of mortgage. just think what it will be in two yrs when fed completely stops trickle down of the faux $$$
  5. BC it is PURE BS !!! just as the light bulb consortium in 1921. mileage warranty is NEVER honored, replacement is $ 3x to use the 40% credit. use to get 90K on tires now it is lucky to be 15K and will NOT pass inspection due to date. for average use not mamas $ to burn them off. bus s use to rent the tires for $.02 ml and get 50-100K
  6. mmi
    Small Sawmills
    we have the same need but $$$$ hundreds of BTO have closed across the country in last 10 yrs ,,ask F 666 what fun it was. defiantly not the time. maybe in 18 months when all the pre orders are delivered. and it hits the fan everyone has a mill..."home" lumber is worthless...not your case they cant pay..even the low pre financing . the shine has worn off...this is REAL work.... ALL brands, excepting several top 3 models, are weekender toss it J U N K. ANYTHING with a '17 > engine is junk expect (25hp minimum )< 2K hr of life. < 4k hr for $25K diesel etc. < $20K units overall have a life of < 3K hrs ,service will be 75% > of new Wm 25-40 and TK 12-14 are the top of the low end, for what you want baker is WAy over $$ IIRC '19 $ it was $.32> bf to own ,+ COG + $ .06-.12 to operate one. watch some vids etc do some leg work. this guy does ok for/on a $5K unit have not found any others consistently using ANY weekender model Josaljo Won 15.3K subscribers https://www.lumbermenonline.com/find-for-sale/Wood-Mizer?manufacturer=Wood-Mizer&makeid=1072 https://www.forestrytrader.com/listings/auction-results/wood-mizer/forestry-equipment
  7. aviation flats? we have used some locks 3x someone should still offer the generic tabs...? MC C..? 6cyl is MUCH smoother than ANY 4 cyl now if it was a continental 193 cross wires, locks, lock tite and then boring to the next size bolt are all the steps
  8. not finding any different # s here either. ? machinist may have a point but could be overthinking for the PARTICULAR engine ? if block is decked then sleeve installed to spec is now x closer to the crank ,thus piston will be the same x closer to the head. critical today and on modified/high rpm engines,maybe some extra space on the d350 ? it will not make for hard starting on gas. indeed both /All parts would require 5x checking on a 188/282 etc.thats why, 6 here are in line $$$$.
  9. cut the BS make the tires properly out of RUBBER make them last 100K and 3 yrs+ ,like they should. just like the gas/fuel make it correctly instead of $$$$$ then we all could get 30-85 mpg truck like a euro vw.
  10. Jeff should have.......think they may be called druz/e clip
  11. assuming the only purpose ,for antiquated /slow design is to pre dry grain for a cheap older/small combine.? for grass/silage with enough HP 14' DB would have about 4x thru put. rough 18% ground is 4-5 mph 9-12th gear, "real" fields (cidioteville now) ,1/4m flat have done 15th. 10 mph
  12. mmi
    Y’All come
    in the 60-70s, that was just family/cousins with in driving distance. (decoration/4th/labor) with birthdays holiday always 25 + 8-10x that we attended. Now not enough to bother with a funeral.
  13. OOOOH you "actually" wanted "service" thats extra $$$ just like getting the lifetime alignment, $300 of other "needed" items we INSPECTED ,then its reset 5 * off so they sell tires .
  14. At least so far here the "farm" plate and cdl do not co mingle as to use /weight. Ie: tractor cow horse etc to (your controlled) field / farm < 150m commodity to sale/purchase, is farm use. Not your bill of lading "item" or to any fair or event which "may" award a participation gift, for hire, is full freight plate. we deliver hay on full freight but ,last 3 yrs that is ONLY to known COD. so its "technically" ours until. CDL not applicable/addition to this equation until 26K #
  15. Definite CDL >>>? Yes it doesnt add up except the $$$$$$ Also how is it $.... across all 4 axles....? 14K # trailer with 10k # load is overloaded.......no
  16. Bh is generally blunt ....1/4" as you will be hitting scalping digging etc at least the first 6x most late model factory/supplied shafts are phased with a fits only 1 way slot or 180
  17. We had those here,could buy a real ( <153 cid )IH for less. Both stealers were jews to them selves.When they couldnt justify the price of ANYTHING, response was " Its dippy what I have to pay" We did get the gutless '62 wagner/ih 800 there in '73.
  18. here 3ph AND non home SERVICE is $$$$$ and you pay 24/7 for it to be there and then a commercial multiplier for ANY actual use. Our home rate was $.90 KWH which went up 40% 6-1 An engineer neighbor converted 1/3 of his barn to 3ph work shop and NG fueler (so it will not freeze) With some type of electronics he built < $2K,he can dial in sync and rpm for each item. another machinist ran his 3ph items with a baby starter motor into (possibly 2x /3ph on 220) wood tomato stake to add load then pop belt off.
  19. yes to a standard but, there would have been slight differences per model
  20. Ie: ta section needs drain flush repeat,as many winters/spring this is where the temp inversion ice/water would collect
  21. IIRC isnt there 2-3 drains for the ta proper? vs just the rear for the 15 gal fill......?
  22. hydreco under license to drott? if the same loader k6/vs k9 but likely larger in vol and rpm/psi....wider bolt pattern
  23. mmi
    Wrist watch
    We always did somewhat collect save/from prior generation (1880) last I purchased was in '85 (battery) <87 was the last worn as the bands always broke they got caught,or scuffed in tractor baler etc. truck had a clock by then. I hate appointments/ schedules,as a rule , if 7 things dont turn up for that slot,then everyone else is an hour late. or you sit at the DR for an hour and he only has 15 min for you and 30 people after you, to support all the GOVT make work/no work $$$$.
  24. that cyl ,(cross ai etc) should be found NEW for +- $150 as the elite scammer on scam bay has them for $250 well used
  25. So the payload is +- 100#, as in the Sikorsky HC was designed as they heavy lift work horse. https://www.google.com/search?hl=en&gbv=2&q=sikorsky+helicopters&oq=sikorski+h&aqs=heirloom-srp.0.0l5
