Everything posted by EJQ
Got the electrall running after repairing some wires and repolorizing the excitor. Works pretty good now. I found some manuals for it. Voltage holds steady. You need to spin it a little faster than 540 to achieve 240v.
I don't think that guy ever used the snow blower. Still has red paint on the cutting edge
I got the snow blower and TM58 electral on the fast hitch. Sitting in line now waiting for my turn.
You picked that up just south of Rush City. I drove by you when they were loaded on my way home from work. I like your truck
Make sure you follow the torque sequence including the part where you you back them off either a full turn or half, can't remember, and retorque. I was surprised by how much more I gained
0.009" is a lot for sure, no wonder it let loose
Betting it was the line between the fuel tank and the frame
I see, I'm in South West corner of Barron County. We had 109 for a heat index yesterday.
Where are you located in WC WI?
Ah yes the golden gear. Been there done that repair.
Any time you'd start complaining about chores or something Dad's response was If you're looking for sympathy you can find it in the dictionary between syphilis and $h1t
Yes, they moved all manufacturing to WI, main building is in Rice Lake. They are in the old Wright Products building next to the onion ring factory. I believe they also purchased a building in Ladysmith WI
I have the same one, still has the seal on the cap under the trunk
Yes High Trans for the Hydro. Not sure on the 966 but the 826 procedure for checking fluid level is to run the tractor for 3 minutes at 1600 rpm, while running pull the stick and check fluid level.
Happy birthday
Got to do what works at the time. Nice looking 10
On my 856 I just installed the gasket and torqued installed the housing. Never had a leak
Prayers needed 3 of my kids injured 2 pretty bad
EJQ replied to Rusty shackleford's topic in General Chat
Praying for you and your family from West central Wisconsin -
You just have to love the the torque those old Pontiac mills make. I know that the 455 in the Grand AM is not the most powerful thing in 75 but it moves that car pretty good for a stock setup
- 80 replies
- 11
