jonbueber
    4
About jonbueber
  1. I removed the power shift control valve and found a blown gasket between the second and third holes in the gasket. (see attached picture) When you look into the transmission case it is a threaded hole but only about an inch deep and it is not a mounting bolt hole. Now wondering what is blowing the gasket. Thanks, Jon
  2. Hi all, I am working on an MX150 that doesn't have any power in second gear. The tractor will pull itself but, if I stand on the brakes I can stop tractor motion without pulling the engine down. Pressure is off at only 175 psi. I have replaced a blown gasket behind the powershift valve, and have split the tractor and placed new clutch disks in input and drop shaft (nothing was really worn out but were in there so replaced discs) also replaced piston packings / teflon collector rings when in the transmission. Looking for advice where to go next. Thanks in advance. Jon
  3. I split the tractor to replace worn out clutch pack disks and plates.  Went through the valve (have an official Case IH tech manual)  Replaced the check valves, checked all of the screens in the valve. When I test drive it I do not have all of the gears or do I feel all of the detents.  When the tractor is shut off, I can feel them and the cable moves freely so I don't believe it is a cable issue since it isn't stiff while off.  This tractor is a four speed reverse if that makes a difference.  any help is greatly appreciated.  Thanks in Advance
  4. 7210 Transmission Valve Issues
    I split the tractor to replace worn out clutch pack disks and plates.  Went through the valve (have an official Case IH tech manual)  Replaced the check valves, checked all of the screens in the valve. When I test drive it I do not have all of the gears or do I feel all of the detents.  When the tractor is shut off, I can feel them and the cable moves freely so I don't believe it is a cable issue since it isn't stiff while off.  This tractor is a four speed reverse if that makes a difference.  any help is greatly appreciated.  Thanks in Advance.
