Iowa5288
Everything posted by Iowa5288
  1. A few pictures of the fireworks at Spillville IA. They don't disappoint.
  2. Boys must feel patriotic this holiday!
  3. I have a chance to at a 5 shank Tebben ripper at a price that I can afford. I don't know what kind of job they do, how rough they leave the surface, and how they handle trash. Anyone with experience good or bad fire away, Thanks.
  4. I have a chance to at a 5 shank Tibben ripper at a price that I can afford. I don't know what kind of job they do, how rough they leave the surface, and how they handle trash. Anyone with experience good or bad fire away, Thanks.
  5. Combined the test plot today. 18 different numbers. Combine numbers looked good considering the year. We'll see how the compare when they get them compiled.
  6. Saw this tractor sitting and stopped to look at it. Looks to be an original at 5700 hr. Everything seems tight yet. The interior has been replaced, but all the pieces are there.
  7. The shank trip force is higher on the 6650 than the 7400. My BIL has a YB8400 and gets his parts through the local CIH dealer. If the frame is broken up I would guess that they were plowing frozen ground. I have some relatives that have raised **** with a pretty new Sunflower that way.
  8. You can replace the gold active terminator with a passive around $18 IIRC. It has the adapter with it. I will see if I can find the number.
  9. You need to check the voltage on the can system, can go and can low (the yellow and green wires) checked to ground should add up to ~5v. Ohm between them at the diagnostic connector should be 60 ohms. If it is 120 you are missing a terminator most likely the one on the planter. Check the ISO connector, I have had to replace pins in that connector. For your information the RE number on that terminator is the John Deere part number. It was $43 at CIH and $78 at Deere last I checked, AGCO uses the same one also. If you need one and one is less than 4 hr drove the cost doesn't matter.
  10. Yes it is a 8 row 30 in. Kinze 3500, finger meters, AgLeader electric clutches with a Incommand 1200. I would have a Case IH but they don't make a 8 row we can get around with.
  11. Some pictures of last Saturday. Put the variety plot in with two insecticide checks. Dad finished up planting Sunday. Now to get some moisture and heat. And the poor view out of the work truck in the afternoon.y
  12. Morning was better than the afternoon. Test plot in this morning, work this afternoon.
  13. DMI Tigermate II field cultivator.
  14. Worked this morning. Then changed oil in my 5288. Rolled some flat Iowa ground to seed oats and rolled the oats in. The BIL came back from working oats ground and went back at the NH3. Dad was on the 686 seeding the oats. Even tied up a couple of the fair animals on the nice day. Happy Easter all.
  15. Heading to Branson from NE IA today. Are there any collections or other things we need to see along the way? We will need to get the kids out a couple of times.
  16. The last I knew Artsway made all the blowers, CIH, H&S, NH,JD, +more. H&S makes the poly sided spreaders and brands them NH. There are no CIH spreaders available new in the USA
  17. It is a 335 with 8 bolt wheels. What Demco 12 ton gears did you have problems with? The standard or low profile, never had spindle issues on the low profiles I have been around.
  18. If anyone is interested the Case IH dealer in Decorah Is has a Demo 365 on an IH gear.
  19. There is a service bulletin that addresses that issue. I don't the number but it involves installing a office fitting in the inlet port of the steering hand pump. It helps with steering chatter and the head raising issues.
  20. The wife and I went for a drive after I got off work yesterday. She got some pics of some red combines in action.
  21. That rear half is the one that lived at NICC in Calmar IA I believe. If I saw it in person I could tell you for sure. The long lever on the shift valve was an easy way to shift it and show what gear it was in for the whole class at once. We would run it with the test gauges on it in transmission class. It was powered by and 8.3 at the time. The engine adapted was "fab shop" built not like a production tractor. The whole thing came in a box in pieces and was put back together by Instructor Dave Amdahl.
