mrfred54
Everything posted by mrfred54
  1. Wow,amazing. That's quite the rescue crew. Kudos to them
  2. Have to remove the seat bracket base. There are three bolts that hold the valves in place. 9/16 wrench. Remove the top center bolt then you can remove the load check assembly to install new oring. Pretty sure it's what you after
  3. Good luck with your new job. Love following your thread. Reminds me of my job back in the 70's and 80's, only without the electronics like today.
  4. Doesn't surprise me at all. Just another government blunder of not caring about their own citizens.
  5. What's next? Our hammers.🤔
  6. Talked to owner on the phone tonite. He's in Louisville to the farm show. Asked him about the driveshaft and he said it is center line of tractor, not offset. No IH casting on the axle. All the seals he got are wrong and ujoints. Small seals on axle shafts leak and large one on the ball socket. Pinion seal is ok. He also said that while disassembly by the IH service manual that the pieces were completely different. He said the dealer is being very helpful and is trying to figure out what he has. When he gets back from Louisville hopefully I can get over to look at it
  7. Not sure. I haven't seen it. I will find out
  8. Friend bought a 5488 last summer and the wheel seals are leaking. It must be after market as he cannot find parts for it. Just wondering what models can be used on the tractor??The identification tag is missing so he does not no what kind of axle he has. What was original axle from factory?? And what after market were available?? Thought I'd ask so he can find parts, maybe someone has come across this before.
  9. Was going to watch it but after the supposedly black anthem started, I turned it off but then decided to watch Reba sing the REAL NATIONAL ANTHEM then I turned it off. Don't think I missed much. nfl is a joke
  10. Has the pedal slipped on the shaft? How much free play do you have? Pedal should have no resistance for about one inch of travel. Also, from your pics it looks like the return spring is missing which holds the throw out bearing away from the pressure plate fingers. Remove the lower inspection cover from the bell housing and inspect the beating and fingers of the pressure plate. With the spring missing the bearing would be running continuously which is not good.
  11. Did you see the mirrors on the( 5088 project ) posts in the technical section. He showed how he installed them also
  12. Rest in peace SIR. Great country artist and paid special tribute to our military. Loved his song RED, WHITE and BLUE. American soldier was another great hit
  13. All the malls are good for is gangs to hang around and cause trouble,steel from patrons and the stores. The mall in flint mi. is pretty much a vacant building. Don't even go close to it anymore. The one in Saginaw is no better.
  14. Is it a true tri stripe? Does it have a hydraulic filter under the left frame rail? Are there variable flow handles at the bottom of the right hand console? Better or worse??? Depended on the owner. Some have been switch back to the old gear pump because of issues.
  15. Would need adapter shaft inside the rear frame from large spline to small and change the linkage from pushing down the spool to raising the spool on older pto units.
  16. Can't believe how some people take care of their equipment. Very nice restoration job😃
  17. Thank you so much. We have had better days. Will post how our daughter's surgery goes, praying for good results. Some sad posts here, but time just keeps ticking away. They say time heals,it may a little bit, but we never forget.
  18. A past co worker and still a very good friend just lost there son. Have to go to the funeral home this evening. His son was a police officer and got hit on the express way ( I-75) helping someone with flat tire. This will be a very difficult funeral. He leaves a wife and very little girl. Then to top this off, we just found out our 45 year old daughter has thyroid cancer and is having surgery later this week. Prayers would be appreciated. So, as the title of this thread, very very sad
  19. With the parts you will need I would go for good used ones unless you can't find any. Most scrap yards should have what you need other than bearings and seals. I did a 1486 last summer,ring and pinion, pumpkin, crossshaft, spider gears, and one bull pinion shaft. My local scrap guy had everything I needed and would guess he has what you need. You should get a good service manual for setting up the ring and pinion, bull pinion, and axle pre load
  20. The dealership I worked at sold a 886 and I had to go to concord dealer to pick it up around 1980. Not much work in the shop so boss sent me to pickup it up. I remember this deal very well because we sold the tractor to a fella whose brother was a mechanic at a johndeere dealer. We could never figure that deal out.😀 Bout a year later he bought a 686 from us. Thanks for the pic and brings back memories.
  21. Now you can buy a seal that threads into the housing if the 540 shaft seal is leaking. No disassembly required
  22. That's quite an extended shifting handle
  23. Welcome aboard sir. When you got questions you will get answers😀
