patricksjohndeeres
    173
Everything posted by patricksjohndeeres
  1. I have found a 1026 IHC wheatland model . How many are not acounted for yet?
  2. I was wondering if anyone would have a spare 7588 or 7788 IHC resin toy tractor 1/16th ... you can email my self at mosset2cylinders@hotmail.com.... thanks
  3. Found two more 1206 Wheatland models in Manitoba, ser number 8567 and 8825 both are running tractors,, these belong to another fellow
  4. I have a 1468 IHC ser #2650118U007408X....... it has been sold going to New Zealand now .. Thanks
  5. How many of these IHC 1468s with a V8 were made ?
  6. anyone making the dust shields for the wheatland IHC tractors ? and what about the step down plates on each side of seat from floor boards to rear step ? used ones would be ok as well
  7. yes need a new fitting for sure, not sure were to get it but will check it out. thanks guys
  8. took the fitting off and it was blocked , I think the ball in fitting that I drilled threw had turned and closed it off again. I used a piece of wire to put threw it again and put it back together, runs good now,, so I will run it for a while and see it it will do it again ,I will have to drill a bigger hole if it happens again , Thanks for the help
  9. that is correct steel fitting on top of pump cover ..I took the return injector line off today as well and blew threw it with air, no blockage there . No blockage to the tank as I blew that out first .
  10. I blew the return line out to the tank nothing in it. I never tried to run it with the line off , I drilled out the bottom little part of the fitting and put it back together and tried it ..
  11. Have a 1256 and it had been sitting for some time, it starts right up and I haver used it around yard a few times, no issues,, yesterday went to use it and started nice ran for about 10 min then powered down and stopped, tried to start again fired up but again powered down. I read the posts that is maybe be return top fuel fitting the issue, I cleaned it and drilled it out and still the same issue... If I loosen the side screws on the small flat plate fuel will spray out and the engine will stay running. the min i turn them tight she stops running.. What could be the issue ? Thanks for any he
  12. located 1206 Wheatland tractors ser 8764 and ser 8958.... they are not mine ....Not sure if you had them listed ...thanks
  13. We did one today with the big wide wheatland fenders with rear entry and also added the front step on left side ,
  14. Have two 1206 IHC Wheatlands , ser 8177 and 8141 ser .. will be converted to open station models
  15. Couple more 1206s Wheatland model user number 8177 which I have now and I know of ser 8141 is
  16. update ser 8857 Wheatland 1206 has been located in alberta Canada
    1. red_reaper
      red_reaper
      Thank you, I did not have it, next in line 8858 was in the Schrock in Indiana and sold at his auction back in 2011, thank you!
    2. redturbo
  17. Not sure if 826 Wheatland model has been recorded yet ser 7812 has surfaced .
  18. the one in MB that is listed above for sale is ser # U016277
  19. Another Wheatland 1206 tractor ser number 8779 is in SK . if this one is not on the list yet
  20. HI, Another collector has two 1206 Wheatlands in SK Canada. ser 8124 and 8274 both running tractors. You can add these to the list .
  21. both of them are Wheatlands and also ser 8640 wheatland 1206 is in Canada
