I believe you would want corporate 902 white. Take equal measures of 935 IH white and case power white and mix. Very ,very close to 902 corporate white.
I have rebuilt a few lift arms. The weld on swivels work well. Make a gage to angle you need and be accurate, cut, grind, weld,grind to finish paint, reinstall.
Use nuts , bolts , ball bearings, and paint thinner , strap to tractor wheel and go on tractor drive. Then clean with water then dump tank bolts and such can be removed with magnet. Rocks will not stick to mGnet. It works
Talked to Russell yesterday. He was saying that the corn is just about ready to tassels. Everything is looking good for this year's show.will definitely be good.
