Everything posted by fbh31118
Kubota Diesel power Super M
fbh31118 replied to DolanVDS's topic in Projects, Builds, & Restorations
That is quite the project you've got there. It's looking great! Be sure to post some video of it running when you can. -
Thank you timbo! I sure hope so. Here is a few more pictures from this week. Nothing earth shattering but as we all know, " The devil is in the details." and there is no shortage of details on this one either. Did run into a snag though, my starter, after starting the engine a few times, began to drag on the ring gear. So, I go to the parts pile and pull another starter off the shelf (that looked like death warmed over), bolted it in and viola, no more drag. That rebuilt starter will be going back to the shop for another look see.
Here is some youtube links of the first fire. Please pardon me as the video has not been edited as of yet. https://youtu.be/VJIzUPW5ORM Here is after making adjustments. https://youtu.be/IY8d2R0PUvE
Thank you timbo! Here is a few more pictured from the other day, hope to get some more done today. A few things not pictured here that are completed; 1st/reverse shift fork changed due to excessive wear, clutch fingers adjusted, valve lash set up for the first time, thrust bearing for the worm gear replaced, original amp meter saved by the removal of brass nuts. Need to get extra compressor set up for sandblasting today so that may be the focus over the tractor but I really should also go get an oil line for the pressure gauge. More important than the tractor has been the time spent with my folks, my wife and daughters and some friends that have stopped by just to say hi. I'm truly blessed!
Made good progress yesterday. All the clutch fingers have been properly adjusted, rails and front bolster are back on and the belts and generator have made it back on. More to do though.
Thank you for asking about the belt pulley! Dad saw one years ago along side the road in a pile of trash from a roadside clean up. Always wanted to make it a perfect original on steel but now that I'm married, it wouldn't be much fun for the girls to run so I opted for rubber. Maybe someday.
I'm going to start with being functional at this point. I had to change engines due to a crack in the water jacket and the original steel wheels were cut off, so it will never be %100 but I would like to leave a little meat on the bone for later, so to speak. I do have a flat belt pulley for it. This is a family tractor that has been out of use since the late 60's to early 70's so any level of operation would be a God send. My parents are getting up there so it need to get done.
Almost up to date. This top picture here just blows my mind. This tractor has set out since the late 1960's or early 1970's and nearly every piece of hardware has come right off. All the bolts on the light bar were this bad and all four nuts came right off. Some of the hex's were so bad that I had to pound a metric socket on to get on and they walked off like nobodies business....... I should be buying lotto tickets or some thing. This can't be the norm by any stretch of the imagination.
Thank you 1206! I'm sure a shop could build one for enough money but I was mainly interested in a good used original, the old brass tanks are hard to beat when taken care of. My goal here is to have a nice original with as many original parts as possible but I'm not trying to be impossible or 'no expense spared' type of guy just nice. We'll see how it goes, if I ever get started this summer......... KWRB Michigan M is correct, they are just stop blocks to prevent the rim slipping. Everybody tried to convince me that the originals were welded in, not true. These were riveted in just like you see in my pictures. The factory probably had a cleaner way of doing it but my way looks original for the outside and wasn't that hard to do. The rivets were ordered from Fasenal and we used a piece of channel iron in the vice to back the rivets. Heat the rivet up with a torch and break out the ball pen hammer and start working it into a head. It really wasn't as hard as I thought it might be and really turns out pretty slick.
My wife and daughters got me a few odds and ends for my H the other day. Still not much work going on yet but soon..........I hope.
Ouch!! Crickets and tumbleweeds.... Can't wait to get the tractor unwrapped from winter hiding and get going this summer, lots of work to do. I'm looking for a vintage Prestolite battery. Hoping to find a vintage 6 volt replacement to add to the resto project.
Wow! Looks amazing!
Came back looking great. I wonder though, why the starter has no tag but the generator does? There weren't any rivet holes on the starter any where.
OK, time for a little update on the ole' H project. After talking to you folks and others in the restoration game I think I'm going to pass on the sandblasting, other than small parts that I can fit in my blast cabinet. I just can't risk contaminating the internals of the trans and the rear end and there are just more hoops to jump through, so that's out. While I'm waiting for the cold weather to break, the starter and generator are going out, like this week so I'll drop a few pictures of my rusty pieces. I can't wait to see how they come back after seeing how the mag turned out. Hope your all staying warm!
Looks great! Some times you take the small wins when ever you can get em', been there a lot lately.....
Started My 806 L.P. restoration
fbh31118 replied to Tonyinca's topic in Projects, Builds, & Restorations
Tony, All I can say is 'wow', your equipment is beautiful and sounds great! I was wondering though, about some of your other projects, do you ever worry about getting rings seated on the ones you don't work as much? Your last post just made me curious. Thanks for sharing your journey with us!!! -
Both of my parents tractors take a few moments to read pressure as well, H and an M. I've put a new pressure spring in my H rebuild so I'm wondering what the difference will look like. My first impression would be that this is normal.
Thank You Sugarmaker! The plan is to sandblast next then prime. It would be nice to get that out of the way before splitting the tractor to install the motor.
I have one more place that I can take it to that is supposed to specialize in copper and brass only but I'm afraid that is may be dry rotted.
Dang it! My replacement radiator can't be repaired..........Argggg! So was hoping I could save an origianal. Which leads me to a question; are all the repops the same or should I avoid any certain ones? Thanks for the input folks!
At last!
