g_man
    47
About g_man
  • Birthday 10/03/1946
    North Eastern VT
    Small Scale Logging, Construction, Hunting, Fishing
267 profile views
  1. That is the same cross bar used on a TD7G all serial numbers if that helps widen your search. I would start a thread here looking for that part. You never know. It will be a salvage part or a welder fabricator job I would think. gg
  2. Parts can be tough. A Komatsu dealer should have under carriage parts and maybe some other stuff so I always start there if I am looking for new. You might find help by asking right here. Or if you can find a dealer who used to sell Dresser's they might help. Some times the only way is to rebuild or modify. What kind of parts do you have in mind ? gg
  3. A little late so hope you found it. On my TD7G the serial number is also stamped on the right hand side wall of the rear main frame just behind the right hand final drive. Most chassis stuff on my Dresser G is the same as on the IH E. gg
  4. On mine there is a plate on the left side of the vertical seat support plate beside the steering levers. Also it is stamped on the right hand side wall of the rear main frame just behind the right final drive. gg
