Tunneldigger
Content Count
102 -
11 GoodAbout Tunneldigger
Rank
- Birthday 08/03/1964
Website URL
http://Houndcity@aol.com
Gender
Location
Southeast Iowa
Interests
Farming, motorcycles, Ag Talk, And IH Forums!!!
What is the difference between them? I thought it was spring reset but a friend told me his 735 isn't spring reset. I have a 730 and am going to use it for the first time
Where was it at?
8My son has a JX100U. It often times is a wonder tractor. You shift from forward to reverse and wonder if it is going to go. It seems much worse when it is in the high side on the 4 four speed. Sometimes it gets bad enough that we have to shut it off and start over. The rabbit on the dash will flicker and nothing happens at all then. Any ideas?
Yesterday I was cultivating with my 856 and turned around on end when cultivator didn't go down. Messed around with draft and went down. A few rounds later and now it will not go down at all. Messed around with draft and nothing. Any suggestions?
Where I work , we have a 1486. It has sat for a year and a half. I went and got the other day. Then the brakes were hanging up. So it went to the shop and they put new linings on it. These guys are good mechanics but don't work on farm tractors. The linkage is free. Where should they go from here?
Will a 1486 bracket fit a 5088? I have mixed new and old weights and don't want to take a chance sliding off the end.
It seems to me that sometime I read that someone makes custom wiring harness . Does anyone have info?
That is really cool, The only thing that I can say my dad owned a Case 530 backhoe 3 times. New off the proving grounds, then off a guy that he didn't sell it to, then off a estate sale. I don't know where it is now.
Yes, That will probably come off.
No weights, but I got them. Some of them are the Keokuk weights, but they will still keep the front end on the ground.
Tunneldigger started following The New Number One
Bought a 5088 today. Didn't they get advertised as the "New number one"? I have always wanted a 88 series. It will probably replace my 1486 as I think the transmission has given it up.
You better not leave that parked by the road!!!!
I just like the 14 backing wagons, cultivating I like to turn sharp and get into the row quick on the ends, seems like sometimes baling its nice to turn fast. In good going we will bale in high 3rd torque back sometimes.
Is a 5088 as nimble as a 1486 as far as turning sharp? Looking at one to replace my 14.
Is there any secrets to replace the rear banjo seals on them besides having lines loose? It takes me alot of swearing to get them changed and then after it still leaked.
