Content Count
260 -
13 GoodAbout oldiron29
Rank
- Birthday 12/24/1959
Gender
Location
Miller Place, NY
Interests
Pre 39' IHC Tractors
TD-9 1948 project
779 profile views
Crawler Guide light mounting bracket for IH
oldiron29 replied to oldiron29's topic in IH Construction Equipment
Have been collecting parts from varies place's, I have a question not sure of what I am finding? Some brush guards the screen is straight across and up and down. Other I have are diagonal. no matter how you turn them the grid stays the same. Did International or Caterpillar make them different? Witch is correct for witch? Never noticed it before. -
I was able to get a mounting bracket from general Gear. Found that a Cycle Ray guide lens from an old knucklehead Harley fits these old style crawler guide lights perfect same size. Has a different pattern on the lens but with brush guards on you can't see it anyway. -
Fuel in oil in “B” style injection pump
oldiron29 replied to north of 60's topic in IH Construction Equipment
Just went through this a couple months back. Could not find anyone that would sell me the seal, only would install lip seal if we send it to them. Mine was leaking so bad it would over flow the fill tube. Fixed now but pricey. -
2250 loader mount brackets for IH884 utility tractor
oldiron29 replied to Clay Haden's topic in General IH
Is it this type bracket one piece each side? -
http://www.ihpartsandequipment.com/images/detailed/3/P5040221_(Medium).jpg see part # 123104C1 this is a 2 hole 4 bolt end cap that recycles fluid and will not make pressure. If I remember right you tap and install flush plug center hole and that will make pressure to end where hex plug is. to supply your loader valve. You must have flow do not dead end anything open center loader valve with flow back into rear end for return.
These light and part are getting harder and harder to find. -
Guy I am in need of one IH crawler Guide Light mounting Bracket. If anyone has one please let me know. Thank you
if you have an air wrench gun you can take the wheels off in 15 mins. or paint everything red. If you try to paint silver and red you will have a mess with the over spray.
mine was a 1984 with front side panel red. brought it in pieces from boxes to this picture. now it has a 2250 on it I can't find the picture.
As 12 guy said board or plywood something to slide it on. Most I have taken the bar and blade off need a lot of heat to get the pins out and a long punch like 1/2" or 3/4" about 16-18" long that will get it in two pieces and it still will be fun.
The new bolts I put in are 4" I guess I should remove filter and check top bolts for tightness.
