RedWisc
    134
1 Neutral
About RedWisc
  1. RedWisc
    Intercooler on a 86 series ?
    I plan on putting an OEM style on our 1586. Mine came off a 1680 combine. Below are the images I've save to help me plan it's install. The first picture is to show where the water can come from, second my dream, third a engine out for better viewing, fourth two kinds of lids for OEM coolers, fifth inspiration, and lastly a case with a non stock intercooler. Hope this helps you out some.
  2. RedWisc
    986 FWA swap to 1586
    Rears are 18.4's, I left notes with front size at work, I'll post another day.
  3. RedWisc
    I counted the teeth on the parts coming off the 986, 38 teeth. Elwood front end, serial # 18005 if that helps at all?
  4. RedWisc
    Thanks for the info, I guess it simply won't work on the 1586 then due to the transfer case. May have to scoop it up for another project, but I REALLY wanted it to be under the 1586.
  5. RedWisc
    I don't know my front ends well, but it's the better one. I'll work on more info. Thanks
  6. RedWisc
    What would be involved swappng a 986 FWA to a 1586 with the 3 to 4 speed, tire size, and 1585 planetary rear end differances to overcome?
  7. RedWisc
  8. RedWisc
    1066 registry
    Pretty much complete, missing some odds and ends, but so far the box O parts has had what I needed.
  9. RedWisc
    ISO 1066 blackstripe rockshaft top cover
    Thanks for the leeds, and no can't be welded.
  10. Looking for a top cover for a 1066 blackstripe. The blackstripe cover is slightly different with a flat spot on the casting for the future 86 series dipstick and fill tube. My friend has a cracked cover, and looking for the correct one for is blackstripe 1066. In the attached picture you can see the casting at an angle where the dipstick would go.
  11. RedWisc
    1066 registry
    No a bought it from a private guy who had it split apart with hopes of doing it but never got to it.
  12. RedWisc
    1066 registry
    Here's a pic of how my 1066 arrived, and where it's at today with the rebuilt TA attached, and rockshaft cover removed to replace seal in the 3 point cylinder. Still quite a way to go!
  13. RedWisc
    1066 registry
    I bought a 1066 in parts last year that I'm slowly getting back together, but it will be a while before it' done. It a wet bolster serial #043566 Madison WI area.
  14. RedWisc
    Oil pump d360
    Ok, thanks. I may look into this for my next engine.
