Posts posted by axial_al
Maybe someone put 350 sheet metal on an H?
43 minutes ago, E160BHM said:
The white horse looks just like my 8th graders made when I was an agriculture teacher in the late 70’s. The plan came from some published curriculum as I remember. We cheated though and used power tools, including a power jointer from the industrial arts shop. It makes a pretty sturdy horse!
1
Are you sure the casting doesn’t have a hairline crack in it? Good luck.
1
I think what it is telling you is that the ramp and roller of the ta over-running clutch were slipping. Eventually it will slip more and more until you install those parts. Most folks install the whole unit as the ta clutch, throw out bearing and ta clutch fingers are probably pretty worn also. Good luck.
Something else to consider is possible bottoming if the head bolts or head nuts since the head is now a little thinner than it was before planing. It would have been a good idea to chase the threads on the head bolts with a die (or the threads in the block with a bottoming tap if the bolts came out whole). Either scenario could cause the head to not be clamped uniformly or enough and cause it to leak at the gasket. Good luck.
7 hours ago, oleman said:
My first electronics project (after I saw the the 67 T-Bird ) was a sequential 8 step blinker project. I thought there would be a commercial use so went all the way with PCB. I used 15 amp FETs so it could blink headlights or other high power circuits. Had blink options like drag the string or individual lamp blink. Many years ago (prior to high brightness LED's), no one was willing spend $ (small batch PCB's are fairly expensive) on it, so someplace I probably have some.
As the owner of a 1964 Thunderbird, I can state with some authority that the 1965 Thunderbird was the first ‘Bird to have the sequential turn signal tail lights. They were controlled by a rotating drum affair with contact points that gave trouble as the birds aged. There are now after market sources that must employ the electronic switching like you came up with. Also, I have noticed that late model Mustangs have sequential turn signal tail lights. Always wished my ‘64 had those!
4
Correct me if I am wrong….thinking my 1970 versatile 400 windrower has 37 degree flares on its steel hydraulic lines. Pretty sure too that 37 degree flares is standard for aircraft fuel and hydraulic applications.
Wow. I ran over a badger years ago with Dad's M farmall. Granted, it was in a plowed field, but he just shook himself off and waddled away. Them buggers is tough!!!
2
Quick question on the quick hitch on that 7230….is that a JD unit? I have one off a 8440 on my 8920. I painted it black too. Boxcar Magnums were some of the best tractors ever made IMO!
Good luck with the Kinze.
2
It would be no problem if you were 30-40 years younger!
1
After losing my border collie Harvey back in February (13 yrs.) I wasn’t sure if I should get another dog that could probably outlive me. It was kind of a lonely Spring without a dog though and when I found a litter of red border collie/Australian shepherd puppies nearby on Craigslist, I decided to take the chance. Been a week now and seems to be going ok so far. Wish me luck with the whole “puppy” thing! This is Molly
14
There is a convenience store at Maustin along that route that has a pretty good cheese selection as well as New Glarus beer we stop at. Not sure where Bloomer is though.
Reminds me of the 71 galaxie that Burt Reynolds drove in White Lightning. 429 and 4 speed in a full size four door car!
2
There is a stamp pad on the upper right corner of the block that will have the engine I D on it.
Heard him live at the National FFA convention in the late 90’s. I have a number of his books also. One of my favorites of his poems was the legend of the cow attack. He will be missed.
1
Gonna say 1968.
1
We have the same problem with them on the edge of a field next to a pasture. I have started scattering handfuls of shelled corn on the edge hoping they will fill up on that and leave the planted corn alone. Mixed results so far. Your solution is more permanent!
1
I have a ‘14 F150 club cab 4X4 with 4 doors. 5.0 and six speed. Love it.
A friend had a duster back in the day….said it was aptly named when driven on gravel roads.
So what was a duster then?
It could have ended up at Basler Aviation in Wisconsin for a turbine conversion…that is where they found “That’s all brother”, the first c47 to carry paratroopers over the English Channel before D Day. The C47 was the military version of the DC3. Anyway, the N number could clear up what became of the International airplane.
1
I have a late 750 that I pull with a mx120 using a closed center adapter I got from my case new holland dealer years ago. I did run it with a 1086 by using a Deere open center kit on the drill, but I think depth pressure in no till conditions was better with the adapter. Will try to get a picture of the adapter later…pretty simple.
Custom harvesting
in General Chat
Posted
I worked for two of our neighbors who were custom cutters the summer of 1968. We left Huron, SD in early June and I remember hearing about Robert Kennedys assassination on the trip. We took US 281 and ended up in the small town of Cashion, OK after an overnight stop at Grand Island NE.
we had two new Massey 510’s with 20’ offset headers. The combines were loaded on the trucks as pictured and explained earlier. One truck was a ‘66 Loadstar with 304 and 4 speed. The other truck was a new CO 1800 with a 20’ box, 392 and 5 speed. A school bus converted into a camper (another international) and a 65 Chevy pickup completed our road train. I think 1968 was the first year of the Massey “triple cascade shoe” and we were having trouble losing wheat over the shoe that was blamed on the offset headers overloading the shoe on one side. Later, we moved to Minneapolis, KS, Superior, NE and then back to SD. Working with a custom crew like that was a lot of fun and I learned a lot too! Wish I had taken pictures!
