planejeff
About planejeff
  • Birthday 11/25/1971
1,974 profile views
planejeff's Achievements
  1. Ford finally did it! The 2021 electric Mustang has to knock out the late 70s Mustang II as the ugliest Mustang ever! Just my opinion!
  2. 3 hr tour! Just because some people might get it!
  3. If an athlete doesn't stand for their nation anthem. They shouldn't be allowed to represent their country!
  4. Prayers and thoughts of her and her family. Get well soon!
  5. I think I would like to have 3 buckets full of IH models from the 50s, 60s, and 70s. I would pick out blindfolded 3 tractors! Sounds fair!
  6. My Dad just restored a 400 LPG. We didn't have any issues with getting parts! It's a nice running tractor. I'm sure that the 450 would be the same.
  7. Cougar is now know as Charlie Brown!
  8. Engine overhauled and power steering replaced with a new paint job! She sounds as good as she looks!
  9. I downloaded a PDF of the Nebraska tractor test results. In 1939 it states the tests of the McCormick Deering B and McCormick Deering Super B. I uploaded a picture of it. My question is what is a Super B? I thought it was like a Super HTA it is a aftermarket thing. By the way you can look up the Nebraska tractor test and select differentdecades. https://tractortestlab.unl.edu/nebraskatractortestlabpublications
  10. planejeff
    300U
    I am going to look at a 300 utility on propane. I run several propane tractors so propane is not an issue. Is there any issues with the 300 tractor? Pros and Cons? Thanks
  11. planejeff
    606
    Just looked at a international 606 diesel. We didn't buy it! I was hoping for a start and go tractor with minimum maintenance. First thing I noticed was a lot of J B weld on the housing! Then a crack on the hydraulic pump housing. Then a crack front axle. The three point arm was welded up. Rear main seal was leaking among other leaks. Then it didn't start the guy grabs a bottle of either! When it finally did start it didn't really know what smoke it should produce gray, black, or blue! Then driving it the hydraulic pump and the steering were in a contest to see which made more noise! The tires in descent shape. So when I started to do the project in terms of money. The 606 was a money pit. We have already had that experience before. Seems like the utility tractor's were used and abused!
  12. The shaft goes straight through the tank via a two inch tube.
  13. My Dad's winter project Farmall 400 LPG! He turned 76 in May! Still works harder than anyone I know! The next winter's project is his brother's Oliver Super 77!
  14. The only recommendation I have is that she should drive it around and operate it. The worse thing she won't get it. The best thing she will get a couple more!
