dhanraha
Content Count
233 -
0 NeutralAbout dhanraha
Rank
A question for you: would that shaft possibly been in a slight bind or something limiting play? Do you need to have the wheel off the ground or the park brake released to check?
Pardon my ignorance, but the end of the pinion shaft is what the brake discs rest on correct? I did check for play when I had it disassembled and thought it seemed tight. Don't have a book in front of me at the moment, what needs to be disassembled to replace bearings? Thanks
I've begun to notice a rattle on the 1256. It sounds to me like it is around the left hand brake while tractor is in motion. It doesn't always do it. When it does, applying the brake usually makes it stop. It got new brakes this summer while at a mechanic's working on the ta. I took the brake cover off, expecting to see something loose or wore. It all looked great. Anyone have an idea on where to start?
Hes had guages on it. He said when the oil.warms up he will lose a littke bit of pressure on the high side, but it will drop off the map on the low side. I think he said he drove it 13 miles and thought he had it, only to have it drop as he got back home. He said he was going to block the seat and brake booster off, but he went through the brake booster at the ta install and would be surprised if that was the problem.
I have a 1256 with a new ta. A while after installation, I had the tellite come on with the low side. I took the machine back to the mechanic who did the installation. He rechecked the mcv and the pump. Reassembled and the same thing. He pulled another mcv valve and put on a new pump, same thing. He says after running a while, lube pressure will begin to drop. I think hes a good.mechanic, but he says hes never seen anything like it and is actively reaching out to other mechanics to see what is going on. I thought I would post here to see what kind of responses this might generate from the wealth of knowledge on the board.
I was always under the impression these were good tractors. A recent post seemed to ibdicat otherwise. What should one look out for? What features are desirable? How many hours can one rack up on these units? I've heard there cab be an issue with park? Is the 52 that much better than the 52 series?
